Air flow
Air flow
I am at a point of turning the injector pump up that I can get it to smoke pretty good if I want and get the egts up pretty fast. So I have come to the conclusion that I need more airflow. Can you get a compressor wheel that will move more air, or any other suggestions would be great.
Thanks
Thanks
You could install an HX35, an HX40 or have your stock turbo machined to take a bigger wheel. I installed a turbo built by Hytech turbo out of Utah. They took a stock H1C and installed an HX40 compressor wheel.
It is difficult to stop a first gen from smoking, their fuel systems can not atomize the fuel as well as P-pump engines. More air is good but better fuel atomization is what is needed most.
Good luck and enjoy BOMBing
ralphyboy
01-17-2008 08:35 PM
8mpg
05-22-2006 01:35 PM
