Air Dog for the 1st Genners
wow...if youre only dropping it down to five psi id say your stock lift pump i doing great or youre not fueling as hard as you think.i could pull my stock lift pump down to 0psi with pods and a fairly mild pump.i think youve got some more fueling potential with the ve if youre currently running 6x18s and you still have 5psi of supply
Indeed it does sound a little off. My report is based on my gauge which i have not had the best of luck with. all 3 of my gauges have ADHD so I only rely on them for aprox. readings. A little off point here but could my setup fuel hard enough to spool an h2e or do I need more stuffs?
Guest
Posts: n/a
We do have a kit for the VE pumps. Give me a call or a pm and we can get you fixed up with the info you need. They are basically an identical kit as the other 12 valve kits other than a 12mm fitting at the pump instead of a 14mm and the pressure is much lower.
Well, I think most folks would take the spare parts out of there to tidy things up a bit.
You would no longer need the lift pump, the fuel filter, fuel heater, and the hard lines to the VE.
i have an ad 100 with the 15# spring. [puts out 12-13 lbs] i cut the angle off the bracket they sent since it wouldn't clear the auto hdwe. drilled some holes in the frame bracket that was left and mounted it straight down the frame. lots of room and the fittings are all looking the right direction. no factory filter. works fine . i used the stock pickup and i can run it right down to empty. tc
bgilbert
05-26-2006 12:15 PM
