Air Box Mods?
Old 07-13-2008 | 04:40 AM
Diesel Jeff's Avatar
Air Box Mods?
Looking for any suggestions for an air box mod to get more air flow for the turbo. Are there any good aftermarket kits that would be a better way to go, or can the airbox be modified to produce the same results?
Thanks in advance for any insight on this.
Jeff
'91 D250
Old 07-13-2008 | 05:41 AM
captcavy's Avatar
get yourself a icebox cold air intake system, with the amsoil 4510 dry nanofiber
filter, it also uses your stock compressor to air box hose
http://www.iceboxmanufacturing.com/
http://www.hollandcourtsales.com/intakes.htm
http://dieselpowerproducts.com/shopp...hp?id=371&=SID
im running one of these, its the best there is for the 1st gen trucks,shelby
Old 07-13-2008 | 08:52 AM
rbrettctd's Avatar
Or go to the sticky and build your own per the instructions there. Much cheaper.
Old 07-13-2008 | 10:28 AM
BC847's Avatar
1st Generation Admin
You can mod the OEM filter box such that it has a much larger intake than originally. . . ..
Or just get an old soup pot, whittle on it some, and shoe-horn it into where the original was . . . .
Old 07-13-2008 | 11:04 AM
check this out..under the passenger side on the bottom of the core support is this little scoop thing. so we cut out the inner wheel house above it so air gets pushed up the scoop into the engine compartment colling things down.
top view--- of what we cut
heres 2 pics of how we modded our airbox...all this took about 30 minutes with a little air saw for the wheel well and a hole saw on a drill.
herb
07-18-2008 08:25 AM
Dinner
13
04-08-2007 10:23 PM
1969mach1
03-18-2007 12:48 AM
guzzirider
02-19-2007 08:01 PM
Hoss
05-21-2004 03:11 PM
Quick Reply: Air Box Mods?
