Air Bags vs Air Shocks
James1, you are correct. The intent of the air bag is not to soften the ride, at least when there is no additional load present. When you have such a heavy load that you would ride on the overload spring, then air bags may soften the ride by providing enough additional force to keep the truck off of the overload spring. Worst than being on the overload would be the sweet spot right before you need it and the truck slaps it on larger bumps.
I would not hesitate to use the Air Lift airbags on a newer truck with a softer ride. But on our bone-jarring First Gen beasts the Kelderman's are probably a better bet. Unfortunately, Kelderman's are expensive.
Correct me if I'm wrong but the kelderman kit replaces/moves the rear leaf hanger and puts a bag between this connection point and the frame. My only concern would be how much the kelderman can change the height between the axle and frame. If it can change it very much there would be concern with dislocating the bag brackets or even separating the bag as they are not designed to be pulled on.
If you are more interested I can contact our technical group and try to get a better handle on any complications this would cause. The biggest thing to me would be if you are adjusting the kelderman setup, if you simply set the pressure and never change it then everything should work fine together. The complication would come from adjusting both of them frequently.
Personally, I am contemplating doing a 4 link with an airbag in the back and taking all but the main spring from the front to put a bag there. Should help ride and carrying capacity.
Posted via Velocity LG ALLY
that is my next project adding air bags over the axel for load , and leaving the kelderman airbags for ride quality. usually I leave the keldermans at a pressure where the truck sits level and it rides great.
The Kelderman kits look very nice, and a great way to improve the ride quality. I was simply commenting in regards to adding both setups to the same rig. I was more concerned with one bag trying to rip the end caps off one of the other bags by overextending them.
Honestly why would you want both? I think it would be redundant. Either use a Big inboard bag and eliminate all but 2-3 of the long leaves of the springs. Or if you dont want to modify so much use the Kelderman if you can afford it.
Oregonian
04-01-2010 10:49 AM
markp
03-12-2008 04:22 PM
