air bags for front lift?
Old 08-09-2006, 10:14 AM
Boatnik's Avatar
I gotta put my two cents in on this one. I too have thought about air bags but the cost doesn't justify the means. The Skyjacker leafs seem to be the best and safest approach. Even with them however IF you are entertaining the use of a snow plow the Factory Service Manual recommends air shocks in place of the factory shocks. Gabriel will make the shocks to your specs for about $150.00 a pair. Of course check with your local state regs. in regards to using air shocks on the front. I read that Virginia doesn't allow them.
Old 08-09-2006, 10:28 AM
jrussell's Avatar
Originally Posted by ruquik
Sure, $900 for two bags is retarded
There is nothing to it, why not just do it the right way and change the springs out. And the original quesiton had nothing to do with plows.
Why no just fabb up a reverse ladder bar sytem and use it with the bags, instead of edit it by using old sagging springs, thar could probably stand to, at the very least, have new bushings put in.
Also, air ride suspensions require a lot more dampening to control the "floatyness" of the bags.
Then why not "just do it the right way" and fab up a whole 4-link w/coilover front suspension?
Old 08-09-2006, 10:34 AM
apwatson50's Avatar
I would definately agree with this!
But the original poster already had the air-bags, brackets, ect... So it would basically cost him nothing. That being the case I would say that the bags would get him what he wants. There is no safety, or technical reason why they wouldn't work for what he wants.
Old 08-09-2006, 11:56 AM
ruquik's Avatar
THIS KIND OF SYSTEM IS NOT A LIFT KIT. end of story.
Because you can only add air to the bag enough to bring it back to stock height (Do you know what height that is?). Any thing added to that to raise it higher than stock will now create two compressive forces going against each other. Basicaly you are pushing the spring the opposite the way is should go, if you dod that your front end will not only ride like crap because the spring/bag conflict but also because you now haw moved the shackle position ( it iwll now be more stright up and down)
Hey, why don't you just throw some aluminum lift blocks under the front . Seriously don't do that.
Old 08-09-2006, 12:32 PM
G1625S's Avatar
I think that's why Kelderman has the installer flip three of the leaves in the pack when installing their front airbags. Being flipped, they're essentially doing nothing but being a zero-rate lift block, especially at stock ride height...a height that can easily be determined by making some reference marks before flipping the leaves. Air the bag up to the reference marks, add some dampers that are up to the task of controlling an airbag and away you go. Sure there are other options, but using a leaf to locate the axle is A:cheap and B:already there, so, since the truck was designed around that geometry, why not take advantage of that while still having many (not all) of the benefits of air? Don't get me wrong, I wouldn't shell out 900 clams for that setup...especially when I found how cheap airbags of all shapes and sizes are at the local Fleet Pride. Got my angle iron at the scrap yard and son't plan on having more than 200 bucks into the whole en-chalada.
Old 08-09-2006, 12:36 PM
ruquik's Avatar
Still, not as a lift though. I would love to have my beast ride like a second gen.
Old 08-09-2006, 12:41 PM
G1625S's Avatar
I agree, not as a lift.
edit: I would think from a safety stand point, some limiting straps would be needed to keep the bags from over-extending in an off-camber or (not that this would ever happen) a hard launch that really rolls the suspension to one side. Either way, articulation would be limited to the design of the bag being used, id think...
Old 08-09-2006, 12:50 PM
ruquik's Avatar
Not a bad idea with the limit straps
Old 08-09-2006, 03:16 PM
keller's Avatar
slightly longer shackles will help when I lift it.
Im only talking about 2-3" hear. I see no reason why this would not work. yes when you try to push down on the leaf to much you will be trying to streach the leaf. but it wold take 6" of so to get to that point.
and $900 I can bag a whole s10 with front back side to side with 10 gallonds of air and compressors for $900
Old 08-09-2006, 07:00 PM
90dodge's Avatar
becareful when just adding longer shackles. you will need to drop the spring perches on the front of the forward springs a evem amont. other wise you will run into problems!
as for the Keldermann system. i have a rear system on my truck and love it. and i am running a 4" lift. its worth every penny if your towing a lot. @ 8k-11k you cant even fill that trailer bouncing around. i am glad it was installed on to my truck when i bought it. i will be upgrading to some 6" springs some day in the near future. and at that point i will be adding bags on the front. atop the springs. not to gain lift, but to soften the ride. point is the keldermann system for the rear is some $$$ but its worth it if your towing! just my opinion on the subject
Bob
CactusPete
03-23-2012 11:43 PM
whiteeye42
07-06-2011 06:29 PM
markp
03-12-2008 04:22 PM
Nonstop
06-24-2007 03:03 AM
RowJ
06-15-2007 01:44 PM
Quick Reply: air bags for front lift?
