After tampering with pump, weird return to idle problem
Old 03-16-2009, 12:17 PM
bgilbert's Avatar
As long as this idle surge/hop doesn't do it while cruising down the road when you hit a bump. That could be a broken plunger return spring(s).
Old 03-16-2009, 01:01 PM
TIMMY22's Avatar
No it does not do it hitting bumps. Only at idle.
Old 03-17-2009, 10:22 PM
carolinacummins's Avatar
Mine does the exact same thing!! I thought I was the only one with that problem? I just attributed mine to wear in the IP, I checked everything else. truck runs great, also does it worse when cold. Cold as in engine cold and ambient temperature cold. When it's warm it seems to be less noticeable or nonexistant. If you aren't careful it'll die on me when I put it in neutral at stoplights, and when making turns.
I'm not even sure when it started. It wasn't even relatively close to any mods though. It even stayed the same when I installed my 366 spring and new piston lp??? I thought it may have been where I lost a thrust bearing, but after new rods and mains it's still there.
Steven
Scotts_D250
07-10-2011 01:05 AM
squarenose
11-02-2009 09:01 PM
GasganoFJ60
09-10-2008 01:11 PM
John Mule
03-11-2007 07:18 AM
RDM16CTD
12-28-2006 01:22 PM
Quick Reply: After tampering with pump, weird return to idle problem
