Adapting a NV4500 with a 2nd gen bell
Guys thank you all so much for the helpful info. Robert
I used all 2001 parts. It had the hi torque mini starter, maybe their starters are different. It was super close to the frame, and if you start it or give it fuel, the engine rocks and it'll hit. You only have to notch the top of the frame, it really doesn't take away any structural integrity I don't believe. It never cracked and I had it in a huge lifted truck that saw lots of abuse.
Ok, so if uses the 2nd gen plate, and bell he already has all he needs is a 2gen starter and clutch slave kit. Are there any differences in the flywheels? Can he use a 2nd gen flywheel and a factory Sachs clutch kit? Or a stock 1st gen flywheel with a Sachs clutch kit? I know that 2nd gens use a smaller clutch does that mean the flywheels are different? And if he uses a 1st gen flywheel will he run into clearance issues with the bell? Thanks
w250_93
02-19-2020 02:54 PM
Alaska Sunrise
02-22-2009 07:14 AM
roverhybrids
0
05-31-2007 08:08 PM
