Ac Refrigerant
Ac Refrigerant
Hi guys,I thought that this may be useful information. I was thinking that my supply of refrigerant is starting to dwindle, 134a specifically. The last time I bought was several year ago, when a certification card was not necessary to buy it. So, I googled if there was anyway to get certified online. Well, there is. it's a 50 question test that is open book and costs 20 dollars. It gives you certification in the recovery and recycling of the refrigerant under section 609 of the Federal Clean Air Act. This one only allows for MVAC (motor vehicle ac) use, but there is also a test for Section 608, which covers non-MVAC systems. I believe that it is also 20 bucks, but I am not sure about that. They told me that the time is about 2 hours, but that that can be extended. You must get 84% and that is 8 questions max to miss. I read the 11 page study guide, that they provide via pdf download, twice, highlighted some things, finished in about 20 minutes and got a 96%, that easy (your experience may be different ). One other thing, the end of 134a production is in 2021, so you may want to stock up, if you have a 134a system. Beware that the test begins as soon as you make the payment...Mark P.S.I am in no way associated with this organization, except as as customer
www.escoinst.com
www.escoinst.com
Hi guys,I thought that this may be useful information. I was thinking that my supply of refrigerant is starting to dwindle, 134a specifically. The last time I bought was several year ago, when a certification card was not necessary to buy it. So, I googled if there was anyway to get certified online. Well, there is. it's a 50 question test that is open book and costs 20 dollars. It gives you certification in the recovery and recycling of the refrigerant under section 609 of the Federal Clean Air Act. This one only allows for MVAC (motor vehicle ac) use, but there is also a test for Section 608, which covers non-MVAC systems. I believe that it is also 20 bucks, but I am not sure about that. They told be that the time is about 2 hours, but that that can be extended. You must get 84% and that is 8 questions max to miss. I read the 11 page study guide that they provide twice, highlighted some things, finished in about 20 minutes and got a 96%, that easy (your experience may be different . One other thing, the end of 134a production is in 2021, so you may want to stock up, if you have a 134a system. Beware that the test begins as soon as you make the payment...Mark
www.escoinst.com
www.escoinst.com
I was thinking recently of driving to Mexico to get R-12 again. My A/C was designed for R-12 and doesn't perform as well with R-134a. Here in the Peoples Republic of Commiefornia, you have to buy it in special cans and pay a $10 deposit on each can. You get your deposit back when you return the cans empty or not.
Edwin
Is this a new thing federally or only in AZ?
Edwin
Edwin
From the guide:'
R-744 is coming, CO2
Acceptable replacements
Edwin
Edwin
The even say they will ship to CA. I bought 6 cans from them a couple years ago with no problem.
Edwin
Well,I learned something, you don't need a card to buy less than a 2 pound container. I buy 30 pounders and I do need a card:
https://www.refrigerantdepot.com/cer...e-refrigerant/
As far as the r12 vs 134a thing goes, my 134a system blows ice. It is important to change the r12 hoses to 134 hoses. They are porous for 134a...Mark
When I rebuilt my A/C I got all new hoses, dryer and expansion valve along with a new compressor. I kept the evaporator and simply flushed it out. I put in PAG oil and the R-134a but I've been disappointed ever since.
If anyone has used one of the R-12 substitutes I would love to hear of their experience. I wonder if I would need to flush out the PAG oil and use something else.
What year did Dodge switch it's A/C to R-134a?
Edwin
There ARE substitutes for R-12. How well they work is debatable. Some are flammable and contain propane or butane. Some are mixtures of other refrigerants which are not flammable AFAIK.
Edwin
Edwin
Many things make good refrigerants, like ammonia for example. I just posted what is LEGAL to put into your system. So, to some extent, what you put in your system is determined by your ethics...Mark
Edwin
Edwin
Thanks greatly.
Edwin
https://www.escogroup.org/documents/609pm.pdf
the part about the replacements is on page 9 ...Mark
Not a problem Edwin,I'll do one better, here is the entire packet and everything you need to know to be a certified refrigerant recovery and recycle technician like me (plus $20)
