ac charge question
ac charge question
does anybody know how many ounces our trucks take from a completly empty system? i had to evacuate mine when i done my conversion and i have found some r12 locally to buy, i just need to know how much to get
There are commercial versions of this available. It's refrigerant C12
If you charge a flat or evacuated system, just dump in the Isobutane first, then the propane (higher pressure). If you pre-mix it in a bigger refrigerant container, you have to withdraw it as a liquid, or the propane will evaporate off first.
It's considerably lighter than freon, so it takes less weight.
Coleman seem to be the best driest available, although I've used Worthington in a pinch.
They've done some safety studies and analysis in Europe. The feared rupture AND fire in a collision are statistically almost impossible. You're much more likely, by many orders of magnitude, to be injured by scrap metal on the road rupturing your plastic gasoline tank and incinerating you.
I'm sorry, my recollection of 2.2lbs is for a retrofitted system charged with R-134a. R12 runs at a lower pressure than R-134a. Since that is the case, if charging with R12, it will take more than 2.2lbs. Unfortunately, I don't know just how much. Somebody else here knows for a fact and hopefully will chime in shortly.
cruizer32
06-14-2013 11:55 PM
