ABS and Parking brake light always on
Light
My parking brake light come on every once and a while and I found out it was the switch on the parking brake lever that is out of adjustment.
Edwin:
Yes! it probably is relay as you described. If you look really closely you can see little metal bars inside (reeds?). That would make more sense. Thanks.
So now what? Where is this pellet fuse? I guess I'll check all the wires again to look for a short.
Jim Lane: thanks, but that's not it. The ebrake switch is fine, this is an ABS problem.
I just had a thought: Maybe Im counting the flashes wrong?
I was counting the long flash as the last flash of the series. Perhaps the trouble is code is #6 not 7?
Code 6 is "Erratic speed sensor". Is this the sensor on the top of the rear differential? Is there any way to test it, or do you have to just replace it?
Yes, I believe that is the speed sensor. Make sure the wires and connectors are in good shape and not corroded. I think it's a thing that screws into the diff and senses a slotted wheel next to the ring gear. It's probably just a coil so you'd check it for continuity. OTOH if it's a hall effect sensor, I don't know how you check those. Maybe you could jack up one wheel and slowly turn the diff and look at the voltage on the terminals. I think a hall effect changes resistance with magnetic flux.
Edwin
Edwin
1stRam
08-14-2012 09:10 AM
Joey-D
12-12-2011 12:52 PM
Stovetop535
01-08-2010 12:47 PM
mr T
02-24-2007 06:42 AM
