96mph 1992 3/4 ton
#31
Had mine at 125mph with a GPS on the dash. My buddy in his done-up rice rocket couldnt believe it. He was doing just under 200kmph and couldnt catch my 1990 1 ton duallie. HEHEHE
#32
My 93 with 3:54 gears falls flat on it's face at 80mph. I don't have the 3200 spring or any fuel pin mods other than having it rotated to the deepest stock point. Even with stock injectors I can roll the smoke with my fuel settings. My 12cm housing spins up pretty quick and keeps it cleared up pretty well unless I lug it.
#34
You guys are crazy! Going over 80mph in a first gen is scary. Especially with a worn steering box, king pins, steering shaft, etc.
I used to make a 5 hour (one way) trip every weekend. It was usually 8-10pm before I got on the road, so most of the trip was late at night. There usually wasn't much traffic, just some trucks and an occasional car or two. Every once in a while a ricer would see the 8-foot long dyno-mite diesel performance stickers on my box and want to play. I would usually just spool up the compounds once and leave them alone. One night there was a car with annoyingly bright headlights hanging just behind me in the passing lane. They followed for a few miles, so I took it off cruise and slowed a few mph so they would pass. They just hung in the same spot. After a few more miles I got tired of the lights and decided to speed up a little. They jumped up beside me and started "playing." It was on at 75mph. I was pulling really hard away from him till a little over 100. Then he slowly started catching up. At 66psi boost, 1550*, and 3600 rpm I was done. He just drove by and kept going. It was a cadillac cts or whatever those things are. I've heard that they go around 150mph, I’d believe it. I think that my 3600rpm equated to 127-128mph. Never did that again. Cant imagine hitting a dear at that speed Kinda wish I hadn't sold that pickup.
Mike
Mike
#36
i can safely say mt turck is slow as edit. ive never seen anything over 70. and that to me was hauling edit. i got a 727 what can u want out of it. hahahahaha its got no edit with that trans
#37
Here is the formula I use to determine rpms. The Getrag has 23% overdrive or .77 gear ratio. With 3.54 gears that equates to 2.73 overall (3.54 x .77). So 2.73 x mph x 366 divided by tire diameter = rpms. The 366 number always remains the same in the equation.
So you guys with 3.07s would have a 2.36 ratio with a Getrag.
For fun; a 235/85/16 is about the same height as a 265/75/16 (31").
If you have 4:10s and a Getrag 75 mph = 2800 rpm; 100 = 3720 rpm and 125 = 4650 rpm.
With 3.54s; 75 = 2220 rpm, 100 = 2960 rpm and 125 = 3700 rpm.
With 3.07s; 75 = 1920 rpm, 100 = 2560 rpm and 125 = 3200 rpm.
I do believe KTA has had his to 135+.
#38
a 265/75 is actually around 32". When I did the math for the 32" vs 31, 3.07 gears at 125, it showed the rpms to be at 3374 i believe. With bigger tires, at the same speed, the rpms should be lower than the 3200. That and I dont think my truck (running 265s) is running 1920 at 75, though I have no tach to prove it. I believe you, just wondering if Im missing something here.
#39
I am not sure of the REAL speed since my speedo only goes to 85,,, But I have seen 3200 rpm in 5th a few times,
Someone smarter that me will know what that all means,
I have 3;54 rear, And the wonderful OD getrag,,
Rear tires are 265/75/16, I think just a tad bigger than the 235/85/16,
I think the truck is faster than I am smart!
Peter.
Peter.
congrats
#40
Well if I can get in, I may be running the texas mile Oct. 28-29. Its a mile track and 1/2 mile slow down on the end....Well see just how fast 3.07s and a getrag will go, I just need to get my 3200 ordered before then.
#41
Bill, with your setup, you were doing 136.5 on the dyno.
KTA has 3.31s (Dana80), and he says he has seen 150 on the dyno.
Mathematically, my pickup, with a limit of 3300rpm will do about 115.
I have had mine up to 100+ a time or two. Gets a little light in the handling after that, esp on local roads. I imagine it'd be smooth on the KS turnpike or I-70 in eastern CO. I have done 85+ for short times (<10mi) in mine with no sweat- handles it better than Mom's 98 TownCar. I also dont need to lose my CDL, so 10 over is it now.
Daniel
Daniel
#43
Mine is still at 35psi at 100 with the egt's heading to jupiter. I get the feeling it will go 110 or better, but i need to bolt on the water/meth to keep from liquifing the pistons.....
#44
