93 Runs Rough Under Load
My first truck, Dad helped me find bought a 93 ctd le, we shipped it to Hawaii. Hard to get a good used work truck here. I picked it up from the dock and in 30 secs it ran out of fuel because the shipping company drained it. Added fuel, cracked the injectors and keyed until I saw fuel, turned off, tightened injectors, great at idle, but under a load the motor shakes as if there is a fuel issue. Still makes speed but there is obviously a fuel issue. I don't know if I did the right procedure. Could be water in fuel, air, ??? Last owner just replaced pump and injectors. Any suggestions on proper procedure or where I should look for tech help greatly appreciated. Justin
It was shipped with an empty fuel tank over an ocean under high humidity conditions - a perfect place for alge growth. I would first try changing the fuel filter. Pay close attention to what you see if you see slime that is pluging it up change - heck I would change it anyway. I would add a biocide to kill the growth in the tank. Hopefully this is all you will need to do - if that.
Bob
Bob
Yup, that's about got it covered....it's amazing that they will run at all with air in the high pressure lines, but they will. Bleed them one at a time at idle for 10-15 seconds a piece..jsut be sure to wear protective eye gear at a minimum--that high pressure can cut skin. Swap the fuel filter just to be safe. Keep us posted. Oh, and WELCOME to DTR!!! Glad to have you aboard!
Greg
Greg
Dodgezilla
02-13-2004 04:40 PM
