'93 Auto trans slips in reverse
Old 04-11-2007 | 03:26 PM
stinkindiesel's Avatar
Thanks in advance for any help- my pride and joy started slipping in reverse and only reverse. I drop it in "R" and it begins to creep backwards normally, but slips when I apply the skinny pedal. When I let off, it seems to grab again and pick up speed, but starts to slip again when I try to accellerate. Before youse guys ask why I'm juicing it in reverse, I park my truck at the loading dock at the end of an alley. A looong alley.
Thanks!
Robbo
Old 04-11-2007 | 05:25 PM
Free89W350's Avatar
I'm not 100% but I believe that you can adjust the reverse band from under the truck. I don't know exactly where but hopefully some one will chime in. Please tell me if I'm wrong.
Ryan
Old 04-11-2007 | 06:25 PM
Yep. Gotta drop the pan to get at the screw though.
Old 04-11-2007 | 07:15 PM
ChrisLib's Avatar
Another vote for a band related problem, the other element applied is the front clutch, wich if that was the problem would show up as slippage in 3rd gear as well. Reason it does`nt slip in 1st is the sprag is the holding element in 1st D range and the low/rev brake doesnt come on till you pull into manual low (L1). Drop the pan and service the unit whilst yer in there, nothing to loose except some coin for the fluid and gasket.
Old 04-11-2007 | 07:18 PM
DODGE 92's Avatar
band
another vote for the reverse band but dont play with it too much or yull do like me and damage it to a point where you cant adjust no more $$$
Old 04-11-2007 | 07:51 PM
blue 1st gen's Avatar
you want just under an 1/8 '' of play on the low /rev band
Old 04-12-2007 | 01:58 AM
bullfrog5.9's Avatar
my rev does the same to i thought trans was going but now i know it not going . i found that if u put it in 4 wheel drive low u can go up hills with more power u can still make it slip but not as easy as if it was not in low
drivesmopars
06-01-2009 09:41 PM
stephenf
07-02-2008 12:06 PM
jhpate
17
05-30-2008 08:08 PM
BearKiller
12-25-2007 11:02 PM
Chrisf
07-07-2003 12:25 AM
