92 nv4500
92 nv4500
I just got hold of a 92 nv4500 with a 30 spline bolt on yoke.The problem is The yoke did not come with the transmission.Can anyone telll me where one could be purchased.Any help would be appreciated.
Most driveshaft shops have a lot of yokes in stock....
Remember you are running the big 1410 joints on the dodge...Which means that it costs alot more than 1310 joint if you are used to those prices...
you might need to adjust the driveline length with the tranny swap.
Let us know what its from!
I believe that some chevy gas motor trucks had them in that time frame... but those would have the wrong input shaft(I think), and maybe a different bellhousing bolt pattern.
FYI,
I have seen some NV4500 conversions that had a bad input shaft depth... carefully measure to make sure your input shaft will have good insertion in the pilot bearing/bushing. if you only have 1/8" pilot engagement, it can fail, which fails the bearings on the input shaft and blows up the tranny... saw it happen twice...
FYI,
whiteknight
12-27-2002 06:28 PM
Hummin Cummins
12-25-2002 12:29 AM
