92 2wd and 4wd frame
how hard is a 2wd to 4wd swap i want to do one in my 91 dodge reg cab but im on a strict budget and can fab up whatever is needed bracket wise. what is needed to do a conversion like this and is it easier to just find a 4wd chassis or a waist of time? thanks guys
If you have a donor frame it's Simple just cut the rivet's out redrill holes and bolt everything back up biggest thing is engine cross member you would have to lift motor up easiest thing to do is pull whole front clip and motor n trans then convert it over then reinstall everything
Trebor
09-13-2011 08:55 AM
oliver foster
05-03-2010 04:57 PM
95black2615
12-20-2006 06:37 PM
