91 with auto not shifting correctly
Any Ideas
Here is what started happening:
freeway speeds
overdrive engaged
started shifting between OD and 3rd
now no OD
Shifts fine in all gears except OD, just as if OD disengaged
Help
Rich
freeway speeds
overdrive engaged
now no OD
Help
Rich
Besides a bad TPS, a faulty trans temp "switch" (the sending unit on the trans line) can cause OD problems.
The first thing I'd try is cleaning and packing the TPS, temp switch, and speed sensor connections with dielectric grease. That took care of my problems for quite a while, but now it looks like my temp switch is bad.
Had the same problem with my 91.5 recently. I dropped the pan, changed the filter and added new fliud. Overdrive is back again.
When OD did stop working it, it stopped all of the sudden and then didn't engage anymore at all. The first drive after the service it kicked right back in again
Good luck
Den
Good luck
Den
Heading out to work on the 1st gen right now. Plan is to do all the electrical items suggested, and if that does not work, then have the trans filter and fluid changed. Though the fluid smells and looks good.
Thanks
Rich
Thanks
Rich
derek111111
02-09-2009 03:06 PM
peanut
08-19-2005 02:53 PM
Zeddy
04-18-2005 11:21 AM
cantfindaname
08-13-2004 10:44 AM
