91.4* Temperature Differential
Old 07-13-2012, 05:09 PM
NE frmhnd's Avatar
We just got a vac pump and can of freon at work. Probably this winter (when I DON'T need it) I'll get my lines off and cleaned and recharge it. Probably had R12 in it yet, since the guy who was too worried about the grill to worry about the AC just broke it open and let it vent.
Old 07-13-2012, 07:05 PM
1st Generation Admin
BC847's Avatar
Originally Posted by j_martin
Running low air flow and cold evaporator can cause saturated or condensing refrigerant to get to the compressor, adding to the load, and increasing both pressure and heat.
I'd be more concerned about the liquid refrigerant flooding back to the compressor and:
- Diluting the compressor's lubrication oil and wiping out the bearings,
and/or
- Slugging the compressor with liquid refrigerant or foaming lubrication oil thus breaking the reed-valves, piston(s), swash-plate, etc.
Old 07-13-2012, 08:58 PM
ClassA4x4's Avatar
It's cool. But why overwork the compressor if you really don't need it that cold?
Instead wearing sweaters when it gets 17 degrees, why not also
turn on a separate heater so you could drive all day in SoCal shorts :-)
Nonstop
11-29-2007 09:24 PM
Hummin Cummins
21
03-28-2003 03:22 PM
Grampaw
02-05-2003 09:28 AM
waam
21
01-02-2003 07:28 PM
Quick Reply: 91.4* Temperature Differential
