'89 Ramcharger 12V 5-speed 4x4 build
#211
Received 1,647 Likes
I am way beyond jealous.......
The following 5 users liked this post by NJTman:
BHD (05-28-2017),
CE_TX (06-04-2017),
jrmcleod78 (05-28-2017),
mknittle (05-28-2017),
MrFusion (06-07-2017)
#212
Looks good, Ollie. The pics kinda look like the ones in the old brochures that one would pick up at the Dodge dealer, that showcased all the RC's, Dakota's, 3/4 and 1 ton trucks of that year. Good background.
The following 2 users liked this post by bigragu:
oliver foster (05-28-2017)
#213
Thanks for loading those picture T-man!
I parked in the field a mile down from my house where you can get the MT view. I thought it would make a good photo backdrop.
I put almost 30 miles on it yesterday and it drove great. The new seats are very comfortable, the suspension modifications seemed spot on and the big pistol grip shifter makes me smile at every shift. It had basically no leaks, the steering was very tight and quick and the brakes where excellent. I had to press the brake pedal lightly or it felt like I threw the anchor out...
I took it to a the car wash and gave it a good bath. The biggest issue was the serpentine belt started squeaking badly a mile or so into the trip. Once back at the shop I pulled a NON A/C belt off a parts donor non I/Ced 12V motor I had in the shop and that fixed the squeak. I will be ordering a new A/C belt for it when I get the last of the A/C seals and such I need to finish up the A/C system.
It was another late night in the shop, re-tourqing 64 lug nuts on the spacers and wheels. I also checked lots of bolts on the major parts that where installed. I did find that the 4 inch exhaust is touching the rear passenger side shock tube as it shifted ever so slightly during the drive. It never got close to or made the area near the fuel tank warm though. I looked into how to modify, re-clock a few tubes and maybe add another hanger bracket to help last night at the end of my "wrenchfest", beer in hand. Beer engineering I like to call it.
I will take it for a another good drive today and keep tweaking it till I get it where I want it.
The following 2 users liked this post by oliver foster:
jrmcleod78 (05-29-2017),
thrashingcows (05-28-2017)
#214
If that clearance issue becomes problematic, remove the pipe, heat up the area that is too close till it's red hot, and use a ball peen hammer to indent it in the shape / clearance area for the shock. It won't affect your exhaust flow enough to be concerned over.
I did that on my down pipe because of the upper lip of the C channel frame was too close. No issue since.
Rubber floor mats next, I assume ?
#215
I have already used the ball peen hammer to clearance two other areas of the exhaust around the rear leaf spring so I could get max fuel tank clearance and around the transmission crossmember just to reduce the chance of any rattles.
I just got back from a 40 mile round trip to hit my favorite diner from breakfast. The truck ran great, the belt squeal is totally gone! The idle seems just a touch high but I will adjust that when I get around to some light pump mods. I am waiting until after the initial road test period which includes the fresh Getrag transmission and South Bend clutch break in period.
The following 3 users liked this post by oliver foster:
#216
I drove the RC 170 miles, trouble free over the weekend other than a squeaky belt the first day. It was a blast.
I am loving the hydroboost brakes.
The past few nights I have still been at it though. The rear axle was drained, cleaned up, the cover resealed and filled up again. The exhaust was moved away from the shock and fuel tank and towards the leaf spring. Two more exhaust hangers where also added. To make that 4 inch exhaust move towards the spring pack work I had to cut 2 inches of the rear of the over load spring on the pack. I am pleased with how it came out.
While on the lift I checked all the driveshaft nuts and bolts and hit the dry frame and underside with some Fluid Film. Once back on the ground I spun the fuel pin to the deepest side and adjusted the high idle screw to use all of the factory supplied throttle linkage throw.
More test driving is needed next.
#217
Great to hear my dream truck is doing well.
Lol
Lol
mknittle (06-01-2017)
#218
It just passed state inspection with flying colors and the RC has another 30 miles under its belt. It is now fully the legal beagle.
Just rotating that fuel pin makes it that much more fun to drive.
mknittle (06-01-2017),
thrashingcows (06-01-2017)
#220
Ever time I do it, it still surprises me how easy it is and how little it looks like it would change things...Yet the seat of the pants dyno. tells a different tale.
#222
Wow it looks awesome!
mknittle (06-02-2017)
#224
Thanks gyman98 and CE TX!
Coming from two guys that have super cool Cummins swaps going on as well! I know you two can appreciate the time and effort it takes to finish up a project like this.
CE TX where are you at with finishing up your crew cab?
gyman98 (06-05-2017)
#225
I'm just about done with all the fabrication of the custom dash/center console and I've started gathering parts to freshen up the 12V. I'd say at least another year.
Current pic.
The following 2 users liked this post by CE_TX:
mknittle (06-06-2017),
thrashingcows (06-08-2017)
