89 D350 CTD Blowing White/Blue Smoke???
One of my parts trucks (a 1989 CTD Dually) runs great and drives too. However, you cannot stand around it because it billows white/blue smoke from the exhaust even at idle and won't go away. I've let it run for about 30 minutes, I've tried revving it and nothing. I"m guessing it's fuel or oil? Turbo problem, leaky injectors, something else??? Any knowledge on this would be great, thanks!
it smells like oil or diesel not sure but it irritates my eyes and can't breathe. I can't see anything visibily leaking underneath the hood so I'm not sure where to begin...
You don't. It's messy, so wear old clothes and eye protection.
It's really not that bad, all you do is loosen the nut a little bit. It's not like a fire hose spraying, just a little spurt every time that injector is suppose to fire.
ok so you're talking about right where the lines run into the top of the injector? then I just do it for each one until it stops smoking and then my problem should be resolved correct?
Well, it won't solve the problem, it will just tell you which injector is the problem one.
Yes, you want to loosen the nut at the top of each injector, one at a time. If the smoke doesn't clear, tighten the nut and move to the next one.
ok great, and thank you for your help! I will try this after my 4 door w350 project is complete because this '89 engine will be going into my next project a 1983 f350 crew 4x4....
crash4wd
12-17-2007 08:48 PM
mike_ward
09-17-2007 01:10 PM
