727 transmission throttle control spring ?
Old 08-25-2010, 05:37 PM
cseby's Avatar
i have an 89,2wd with a 727 automatic.my question is do i need the throttle valve return spring?( pn 53009055)that's the spring that runs from the transmission throttle control cable to the injector pump lever ball stud. i have high gas pedal effort form 1/2 to full throttle. with the spring removed the gas pedal operates with much less effort.the big question,and can't seem to find an answer from any local experts is,how will disconecting this spring effect my transmission? don't want to mess something up,because i just don't know exactly what this spring does.i looked through many threads for pictures and some have this spring and some don't.this question has plagued me for some time and i just can't find the answer.any help or thoughts appreciated.
Old 08-25-2010, 05:50 PM
Free89W350's Avatar
I would say leave it because it helps it return. You could probably get away with removing the inside one that should make it easier moving.
Old 08-25-2010, 06:02 PM
cseby's Avatar
which spring do you mean by the inside one?
Old 08-25-2010, 06:08 PM
Free89W350's Avatar
the one that goes from the pump to the bracket that is bolted to the front of the case closer to the front of the truck.
Old 08-25-2010, 07:06 PM
Yes, you need that spring there. If your pedal effort is high, check the bellcrank for rust on the shaft.
Also, like Ryan said you can pull the inner throttle return spring out of the double throttle return spring. There's a torsion spring on the throttle lever so you still have a fail-safe.
Old 08-25-2010, 07:41 PM
cseby's Avatar
i'll check for rust.can you tell me what happens in the trans if the spring is not connected?
Old 08-25-2010, 07:54 PM
1st Generation Admin
BC847's Avatar
There's bushings inside that bellcrank. Mine were substantially worn. Had to remake them.
Old 08-25-2010, 08:09 PM
cseby's Avatar
just never gave that a thought.will check into the bellcrank this friday .i was thinking spring tension was my problem,but i bet the bellcrank is binding.
Old 08-25-2010, 08:51 PM
Onemoparnut's Avatar
Dont mean to hijack but Do the 518 trucks have that spring also because mine sure doesn't.
Old 08-25-2010, 11:07 PM
Gots_a_sol's Avatar
Mine has the same spring set-up as in the first post.
Old 08-26-2010, 04:34 AM
JustRamIt91's Avatar
humm.... i'm confused now. I asked the same questions a few months ago... and i was told there was no such spring so which is it???
Old 08-26-2010, 04:36 AM
It seems that there is a metal sleeve that protects the steel cable inside. Mine had come apart and was causing a bind that wouldn't allow for smooth pedal movement. Fixed it with a set of wire crimpers and some epoxy.
Old 08-26-2010, 03:49 PM
archer39's Avatar
there should be a spring on trucks with a 518 also.
Old 08-26-2010, 04:17 PM
Maybe that would explain my erratic shift points sometimes.
Old 08-26-2010, 04:35 PM
archer39's Avatar
could be but the 3200rpm gov spring and the throttle linkage ball swap makes these things shift weird. I am still trying to fingur out a way to make it shift right.
Quick Reply: 727 transmission throttle control spring ?
