1st Gen. Ram - All TopicsDiscussion for all Dodge Rams prior to 1994. This includes engine, drivetrain and non-drivetrain discussions. Anything prior to 1994 should go in here.
My year breaks may not be correct. Wondering about door fender line matching using '75 D700 fenders on an ''84 crew cab body. Have been wondering what I can do to replace a very beat/rusted cab on a D700 with a '84 crew cab that popped up for sale recently. The D700 cab seems to be a standard pickup cab. See pic. Anybody done something similar ? Want/need to change cab but keep fenders/hood/grill.
I have read the body lines on the later doors interfere with the early fenders.
Check the cab carefully - floor, mounts, tunnel, firewall. The Chevy and Ford MDT cabs had enough differences to make a simple swap with a pickup cab a bit of a headache.
Thanks for your reply. Do you recall where you read/heard about this interference ? Still have room to doubt if you are not reporting first hand experience. I do see that the D700 cab has some add on pieces where inner fenders bolt to firewall so what you say jibes with what I see. But untill cabs, regular pickup and D700 are side by side seeing every difference will be difficult. Potential interference with later doors would be a problem. Clearly a '72 - '81 4 dr cab would be the better choice to start with but not as common or as inexpensive as this later cab that fell into my lap.
I read the body line detail either here or ramchargercentral.
I own both styles of doors and fender but have not mixed and matched yet. I can see how the line on the door might grab the early fender. As far as I have read, the older doors can used with a newer cab.
I like the idea of using the early doors on the later cab. That would seem to solve the fender/door interference issue. Appreciate you hanging in there to explain and share.
You can swap, beds, doors, hoods, fenders and cabs around '72-'93 for the 1/2 to 1 tons. Yes some body lines might change but they should bolt up and work. Obviously putting different length beds and cabs on trucks will make issues with fitment.
I have heard the D700s use the same cab as the 1/2 to 1 ton trucks.
the fenders are different on the D700 with the massive flair to them.
Appreciate you chiming in oliver. The D700 cab in my pic is a regular pickup cab in every way i've thought to check. As stated in earlier post there are a few add on brackets in firewall area giving the unique inner and outer fenders additional/different mounting points compared to my 1/2 ton picckup of the same year.
