6bta rotory motor
Old 03-25-2008 | 08:13 PM
dodgec68's Avatar
6bta rotory pump motor
I found a 6bta cummins motor and was wondering what the difference between pumps and blocks there are, the guy says its a 250 hp pump, any difference or is it just turned up? also has the water to water after cooler, wondering if its worth 300 bucks, guy said it cracked the exhaust manifold and got water in the cylinders
all comments appreciated
thanks Jesse
Old 03-25-2008 | 11:42 PM
BearKiller's Avatar
The pump core is worth a lot more than that.
Old 03-26-2008 | 01:48 PM
dodgec68's Avatar
would it work on our motors?
Old 03-26-2008 | 02:35 PM
roxxx's Avatar
Not 100 % on your motor but i have seen industrial motors that were in firetrucks and few other applications that were rated higher HP than the Dodge Cummings. these had ve pumps in them too, they were similar motors. Same as the marine motors only problem is they are very hard to find because they had such a long duty cycle on them and when they went out they were scrapped
Old 03-26-2008 | 03:20 PM
99globalwarmer's Avatar
i thought they had some little upgrades like thicker or better steel in the blocks, heads etc. i thought sheid diesel trys to find industrial motors for that reason, if everything is the same but the hp then ya it should work fine.
sdmark
Cummins Conversions
47
04-30-2020 01:12 PM
Douglas2
06-15-2011 03:05 PM
coupdetat
02-17-2007 12:52 AM
W900A
11-23-2006 07:31 AM
patriot pearl blue
12-29-2004 06:47 AM
Quick Reply: 6bta rotory motor
