60mm Compressor Wheel
Old 07-19-2010, 11:16 PM
ebteckx's Avatar
It will be here on Wednesday... I am already trying to think of excuses for work... Quick question though, I also bought the rebuild kit for the turbo which after resealing the VE looks to be a cake walk, do I have to have this dude rebalanced???? Thats the only thing I cant seem to find... Thank you very much I am excited!!
Old 07-19-2010, 11:53 PM
peobryant's Avatar
Nope, don't need to get it balanced.
Old 07-20-2010, 01:35 AM
JQmile's Avatar
Didn't rebalance mine and it was fine up to 50psi.
Old 07-20-2010, 03:20 AM
Bigone721's Avatar
You should have no problem with the rebuild, hardest part is getting the exhaust housing of if it has been on there a while (I usually use the propane torch). Also remember that some of the shafts have left hand threads and some have right hand, you can usually see the last thread on the shaft sticking through the nut and figure it out from there.
Old 07-20-2010, 07:47 AM
dzl_damon's Avatar
If you want to be picky, make a mark on the shaft and compressor wheel to line them back up. More preferable is a mark on the top of the compressor wheel, and corresponding spot on the backing plate. Then do the same on the turbine side. Easier to line up with less error.
Old 07-20-2010, 08:48 AM
JustRamIt91's Avatar
an easier way to tell if its left hand threads is to look at the nut. The nut will have a series of round indents on it. Similar to that of a grade 8 bolt but round instead of squareish.
Old 07-20-2010, 09:09 AM
ebteckx's Avatar
Sweet!! I cant wait, my trans is really gonna hate me, the last major performance upgrades Im doing to this pig after this is the M3 pin and timing spacer. Then its time for tranny, head gasket and studs suspension and all that. You all are great thanks for the answers!! Ill let you know as soon as its on!
Old 07-20-2010, 09:31 AM
1STGENFARMBOY's Avatar
Let us know the results as soon as you can.
Dar
Old 07-20-2010, 09:35 AM
Onemoparnut's Avatar
I cant wait he hear how this works out.
Old 07-20-2010, 10:19 AM
Midnite's Avatar
I'm curious--are you installing this compressor wheel on your stock H1C?
Old 07-20-2010, 10:36 AM
ebteckx's Avatar
yes and no, it is the stock turbo, but Im going to rebuild it when I put the compressor wheel on and I already replaced the turbine housing with a 16cm non wastegated housing.
Old 07-23-2010, 10:41 PM
ebteckx's Avatar
Okay, quick question... got my compressor wheel and rebuild kit. So so excited to do this on Sunday, on the compressor wheel there is like a half moon machined cutout on the back of the wheel and then the face where the nut would meet there is a machined flat. do these have any importance to installation? Thanks guys!!!
Old 07-23-2010, 11:18 PM
Pod Boy (on hiatus)
SOOT4BRAINS's Avatar
These are cuts they make to balance the wheel. It does not make any difference for installation.
Old 07-24-2010, 06:39 AM
ebteckx's Avatar
Thank you soot!! Work is gonna suck today, all I can think about is getting home and rippin into that dude!!
Old 07-24-2010, 04:26 PM
deanhinsley1963's Avatar
let us know how it turns out!!!!
Quick Reply: 60mm Compressor Wheel
