518 transmission with 3.08 gear?
Is there anyone running a 518 transmission with 3.08s?
If so, how is your fuel mileage running empty?
How does it do with a load, say around 10K?
Thanks, Tom
Valley Center, Ks
Thanks, Tom
Valley Center, Ks
If I'm not mistaken the 518 1st 2nd and 3rd is the same ratio as the 727 trans the difference is the OD ratio and the extra gear. I will be running that set up hopefully by the end of the year. I am getting a best of 18 mpg's out of my 727 with 3.07 and I am hoping to get into the mid 20's once it's all said and done.
My 93 dually ran around 20 MPG with OD and 3:08's empty.
With a 10k load I would run around 13 MPG. I hauled a load 775 miles at 70 MPH for this fuel figure.
RPM at 60 MPH is 1650 with 235/85/16R tires.
Thanks for the response guys!
I am already getting 20 mpg city and suburban driving now.
I just don't like the 80 mph top end and the high revs.
My pinon bearings are getting bad, and 308 gears are hard to come by in the case that I might have to replace the gears.
I might be parting out a 92 dually because of title problems and thought of using the 518 trans in the 90.
Again thanks for the interest.
Tom
Tom
Going to the 518 will make the truck a lot quiter at the speed limit. 1650 RPM at 60 MPH makes for a quite truck.
If you have the 518 all ready go for it. You will not be disappointed. Get those bearings replaced ASAP.
The bearings are the same as far as I know.
I normaly don't buy the bearings till I have it apart. I just take the numbers off the bearings and races that are in it. Saves some headaches that way.
91Hoopty
09-13-2013 08:51 PM
