A-518/ Transfer CASE SEPARATION
Old 12-08-2006 | 06:12 PM
bhoff1175's Avatar
Ordered my torque converter today. I was wondering if their are any special
tricks to separating my Trans from the transfer case?? I removed them as 1 unit and I would rather do the reinstall in 2 steps.... trans first, then bolt up the transfer case.
I am planning 2nd Gen flex plate, shift kit, Hughes TC, Rear
seal.......Should I do anything else while i have her apart??
Bryan
Old 12-08-2006 | 08:29 PM
JD730's Avatar
Just unbolt it and be prepared to catch the heavy thing and the oil thats going to come out from that area. There's a gasket there, either make a new one or use RTV.
When I do I always do it as one unit, if you don't have a good trans jack then I would do it as two separate units.
Put a trans input seal in while your there.
Old 12-08-2006 | 09:26 PM
Ilikebikes's Avatar
NP205s are heavy. Hopefully you have a tranny jack!
Old 12-09-2006 | 05:58 AM
JD730's Avatar
If you use a trans jack, make sure you strap it down good because that heavy transfer case wants to drag it off the jack.
Old 12-09-2006 | 07:02 AM
DODGE 92's Avatar
tranny
if you take it apart on the truck just watch for that plug in thats close too fuel tank its pretty close dont want to brake that
Old 12-09-2006 | 09:53 AM
bhoff1175's Avatar
Thanks for the advice, I'll look into renting a trans jack.
Looking forward to my new TC. and improved MPG
Bryan
Old 12-09-2006 | 10:41 AM
JD730's Avatar
Thats right, watch the speed sensor, you can break that thing quicker than you can say shoot.
Old 12-10-2006 | 12:04 PM
DODGE 92's Avatar
tranny
you dont need a tranny jack i just took my tranny off without one i bet its even easier with transfer case out just get some normal jacks and some ratchet straps you shoud be fine and iff you only need to take transfer case out tranny jack is money down the drain if you ask me take a normal jack and strap it on and use ratchet strap for safety
Old 12-11-2006 | 01:18 AM
1-5-3-6-2-4's Avatar
if it is a np205, be ready it weighs in at 175lbs.
............second only to the hunk of steel called the 203 in at 190lbs
2500TurboDodge
04-24-2006 02:34 PM
2500TurboDodge
01-25-2006 07:40 AM
BigBlue
02-12-2005 11:36 AM
richard
01-03-2003 08:17 PM
Quick Reply: A-518/ Transfer CASE SEPARATION
