4x4 727 to getrag swap
Old 07-11-2014 | 10:45 AM
  #46
w250 guy's Avatar
Originally Posted by Philip
Install the M/C bracket before the pedals.
Yes i agree that would be the best route! Haha and i will have to take a look again for the clutch forks and see what i can dig up.
Sent from my iPhone using IB AutoGroup
Old 07-11-2014 | 06:10 PM
  #47
w250 guy's Avatar
Does anyone know what ratio adapter would be needed for a t case geared for 4.10s and my truck has 3.07s i believe it goes in %
Old 07-11-2014 | 09:35 PM
  #48
Philip's Avatar
Originally Posted by mknittle
I better do that before I end up doing it twice.
You wouldn't do it twice. With the pedals out of the way you can get a ratchet on the mounting bolts. With the pedals installed your laying on your back turning the mounting bolts with two wrenches. Those 4 bolts seem real long doing it with wrenches. BTDT
Get the swap done. See how far the speedo is off. Then we can go after that problem.
Old 07-11-2014 | 09:45 PM
  #49
mknittle's Avatar
LOL I know, But I have done stuff like that right after I thought not to.
Old 07-12-2014 | 10:28 PM
  #50
w250 guy's Avatar
Well got the pedals swapped, and the master cylinder in my truck! Ordered new trans mounts, clutch release bearing assembly, slave cylinder, and the front seal for the input shaft (which was a PITA to get by the way) got a brand new clutch from the owner of the donor truck too. The fly wheel looks to be in good shape, any opinions on that? Plus a question off topic but what would you recommend for a tach kit?
Old 07-13-2014 | 08:04 AM
  #51
Philip's Avatar
We all have don't feel alone.
If its a new clutch and a used flywheel. Turn the flywheel.
Your a nonIC truck. A 2888 AutoMeter is best bet. It hooks to the alt.
Old 07-13-2014 | 09:05 AM
  #52
mknittle's Avatar
Have the flywheel resurfaced at a automotive machine shop.
Old 07-13-2014 | 09:41 AM
  #53
w250 guy's Avatar
Okay ill have that done monday, and thank you for the quick responses!
Old 07-13-2014 | 02:33 PM
  #54
Well a Tach for your 90, Non-IC truck, will have to use the magnets and magnetic pick up off the crank, or the kit that runs off the alternator.
You can order an Isspro Tach, and magnetic pick up kit from Geno's. I have have had good service from Geno's and would recommend them.
Here's an example of what you can order.
http://www.genosgarage.com/ISSPRO-R5.../#.U8LQiLH5fSg
There are other gauges available too. Just do a little searching for the one that you like best.
Old 07-13-2014 | 02:43 PM
  #55
mknittle's Avatar
I have an un known brand tach with a Stewart Warner magnetic pick up on the balancer. it is tougher than it looks. mine got knocked out of place when a fan belt came apart. I bent it back and it works fine.
Old 07-13-2014 | 06:23 PM
  #56
w250 guy's Avatar
How accurate are the ones that use the alternator for the aignal?
Old 07-16-2014 | 11:51 PM
  #57
w250 guy's Avatar
What would you recommend for oil in the getrag and how many quarts?
Old 07-17-2014 | 09:52 AM
  #58
I used Mobil 1 5W-30 last month when I was installing some transmission cooler plates on my Getrag.
IIRC it is 4 QT to fill it to the fill plug, then it is best to add another QT.
I have used the upper PTO bolt hole to squeeze in the last QT.
I have also poured it down the shifter hole once it has been pulled out.
Old 07-17-2014 | 01:00 PM
  #59
w250 guy's Avatar
Alrighty thanks!
Old 07-20-2014 | 11:01 PM
  #60
w250 guy's Avatar
Got the standard in the truck finally! Boy what a difference. Just wanted to thank all of you for the advice and tips throughout the swap!
