4x4 727 to getrag swap
Well almost got the tranny out of the donor truck today but somethings hung up and i cant figure it out. All bell housing bolts are out, all the linkage is off and the crossmembers out but the thing wont budge! Am i missing something? Any help would be awesome!
Sent from my iPhone using IB AutoGroup
If you are sure you have all the bolts, try gently wiggling the tail stock to see if there is any movement at all, if none, go back over the pattern yet again. If there is some, it could be just hung on the dowel pins, they will corrode on sometimes. Keep gently wiggling back and forth and it should loosen.
Do you have it on a good trans jack? That puppy is pretty heavy and if it comes loose all of the sudden, it can be a handful to control.
Ended just being some corrosion, and i meant the standard tranny by the way, now my next question is about the arm that the slave cylinder hits to disengage the clutch. Its bent and i need a new one but im not sure what its actually called any ideas?
http://www.phoenixfriction.com/p-409...el-engine.aspx
$ 66.89, for the opportunity to not have to pull the trans again, I would go new.
