4200 spring
I don't know anyone who has a 4200 spring in
Heres my experience with the 4200rpm spring. Ive had one in my truck, the throttle is really really touchy. It was hard to get used to especially in town. In my truck I found that the pump had to be maxed out for it to work, cuz if it wasnt it liked to cut out a 2500rpm. Its ok i guess but the people Ive talked to said that no matter what you do the VE, it can only fuel so far. If your seeing that kind of rpm you also need to upgrade you plunger return springs in the pump. A floating plunger is bad.
Take a look at 'the man's' dyno sheets, KTA. He makes all his 'big' power before 3200rpm. Sure he ran them out to 4000rpm, but it didn't make much power out there. He also uses the 366 spring, well last I asked.
I still would like to find a spring setup to fuel to 4000. Keep up the R&D guys.
