40mph viberation
Old 02-10-2010 | 12:49 PM
whosdunit's Avatar
40mph viberation
I have a viberation at 40 mph, new shocks , wheels spun balanced,centered my wheels w/lugnuts, smooth above and below 40 mph. Any one else have simular problem. whosdunit.
Old 02-10-2010 | 01:04 PM
How's the center bearing on the driveshaft?
Old 02-10-2010 | 04:05 PM
hounddogks76's Avatar
Does it feel like the front end or from the driveline?
Old 02-10-2010 | 04:24 PM
dzl_damon's Avatar
Did you leave those centering nuts on the front wheels? I didn't and hit a big bump and they went out!!! It was a pretty hefty pothole though. Anyway, centered them again and left the 2 centering nuts on this time. Vibration was gone.
Old 02-10-2010 | 05:18 PM
ups132's Avatar
im having the same problem that feels like its in the driveline. replaced the carrier bearing on the driveshaft and balanced the tires. needs new shocks for sure and i dont know what the centering nuts are refering to. any help appreciated here also
Old 02-10-2010 | 05:22 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
The centering procedure is for DRW trucks only.
Have you checked your yokes for wear or a loose nut or slip and stub on your driveshaft?
Old 02-10-2010 | 05:32 PM
don't forget about U-joints...I've seen and had more mystery vibrations that were caused by U-joints than you can shake a stick at! You can rotate a driveshaft all day long while looking at the joints and the caps, but if the cap is cracked or broken on the back against the yoke, you'll never see it until it's too late. I found out the hard way, had the mystery vibratoin for 3 months and couldn't find it, Was on the highway and it started doing it...so I floored it up to 75 and all hell broke loose. Busted the tailshaft housing and the rear crank case cover. That was one expensive U-joint!!!!!!!!
Old 02-10-2010 | 05:45 PM
whosdunit's Avatar
Thanks every one ,will check center bearing for sure. cked u joints no slack.
DZL did not know to leave center nuts on,but centering sure works to smooth things out. whodunit
Old 02-10-2010 | 05:54 PM
schamran's Avatar
Tight wheel bearings?
Old 02-10-2010 | 08:16 PM
93flatbed's Avatar
When you had the wheels balanced what was the road force of each of the tires?
Old 02-10-2010 | 09:04 PM
whosdunit's Avatar
I wasn't there when the shop put on shocks& balanced wheels. checked with shop today said he only balanced front 2 wheels. I ask for all 6 to be done. SOOOOO, i can't answer your question (93/flatbed).
Old 02-10-2010 | 09:45 PM
dzl_damon's Avatar
I don't think they are SUPPOSED to be left in, but I do since I've had a big enough bump knock it out. Granted I didn't torque to 300ft-lb like we're supposed to on these 5/8" lugs, I just know it was "wicked tight". My torque wrench only goes to 150ft-lb.
Old 02-10-2010 | 10:03 PM
torquefan's Avatar
You may have to remove the driveshaft to give the u-joints a good inspection. Joints with slop aren't the only source of a vibration, you may have one that is seized up.
phatboy
12-07-2008 08:16 AM
1crazytruck
07-28-2006 12:58 PM
c_dawg
12-22-2005 05:15 AM
kev94mx
12-20-2005 09:57 PM
Quick Reply: 40mph viberation
