400deg pyrometer temp on shut down
Old 06-30-2009, 08:43 AM
apwatson50's Avatar
Originally Posted by Jer12377
I don't see any wet spots or leaks in my fuel lines?
Which one of these are DDp3'3 http://www.dynomitediesel.com/prod_d...irst+Gen/0.php . Or am I on the wrong page?
You can have an air leak without a fuel leak, pressurize the fuel tank with less than 5psi of air, then go check for wet spots.
The first ones on that page, the ***50lpm.
Old 06-30-2009, 02:00 PM
Jer12377's Avatar
Location: North Haven,CT "Living in occupied teritory" & Barton,VT
Thanks. Do you have a suggestion for a turbo to go with them? I was looking on eBay and I found some in my price range. I am sick of being in second gear climbing hills on the Interstate with my trailer, and if I have to replace the injectors I might as well go for broke and change the turbo also.
Old 06-30-2009, 02:05 PM
apwatson50's Avatar
I'd go with a super hx40, or one of the smaller s300 variants that all the diesel performance shops sell. Or if you don't want to spend a bunch of money on a turbo, it seems people are doing well with the 3rd gen turbo the HE351.
Old 06-30-2009, 02:09 PM
apwatson50's Avatar
from 1stgen.org
"Chuck @ NewEradiesel.com 740-819-0457
stock 1st gen inj - 6x.009" = .000380" total cross sectional area
2nd gen 215 tips - 4x010 = .000314(17% smaller than stock)
non ic inj - 4x12 = .000452 (19% larger than ic inj)
185's = smaller than stock
190's = smaller than stock
230's = ?
300's = ?
ddp stg III = 50 LPM (liter per minute) 5 hole extrude hone inj
330's - 5x11 = .000474 (20% larger than stock)
2nd gen 370's - 5x12 = .000565 (48% larger than stock)
ddp stg IV = 55 LPM (only 10% larger than stg III's) 5 holes <.013
pods - 4x14 = .000615 (62% larger than stock)
2nd gen 435's - 5x014 = .000769 (twice as large as stock)
custom injectors -
6x13 = .000795
5x15 = .000882
6x14 = .000923
5x16 = .001005
6x15 = .001059
5x17 = .001134 (300% larger than stock)
6x16 = .001206
5x18 = .001272
6x17 = .001360
5x19 = .001416
6x18 = .001526 (400% larger than stock)
5x20 = .001570 (josh ayers custom p-pump inj)
6x20 = .001884 (500% larger than stock)
5x22 = .001900
5x24 = .002261
6x22 = .002280 (600% larger than stock) "
Also personally I think i'd like to try some 6x12 or 6x14, but probably some 6x12 injectors. They should put out lots of fuel but still be small enough to burn clean while idling. My opinion, might be wrong though.
Old 06-30-2009, 04:56 PM
NotEnufGarage's Avatar
I just upgraded my non-I/C motor to a 54mm compressor and 3" crosspipe. It'll drop down below 300 in just a minute or two at idle. Before that, it would take about 3 minutes to drop to 350.
I suspect the I/C trucks don't do so well, since the restriction of the intercooler and you're not getting any cooling out of it when idling and sitting still.
KATOOM
18
07-27-2007 09:37 PM
4x4not
05-16-2005 10:16 PM
jt
03-25-2004 11:35 PM
rangerst
03-24-2004 02:52 PM
kstrongsyj
41
05-30-2003 09:35 PM
Quick Reply: 400deg pyrometer temp on shut down
