4:10 gears in 1st gen
But do the 4.10 gears let you launch in third? What happens then? Might be worth it to start really slow if you can get a full power-band run?
don't race my truck........not much that much
and i just put a new clutch in it and dont want to slide the clutch that much.
Originally Posted by Begle1
Well, you know about all of my experiences driving manual trucks... I don't know what they're capable of... (I'm sure I'd be just as good at stalling it out in third as I would be in first...)
I try to baby my truck,...untill my wife and her ford sport tacker things that she can blow my doors off. I had a give her a lesson w/black smoke
So at least you managed to get her sooty while she blew your doors off?
When it was stock she blue the doors off of me and then i did a little tweeking of the pump and she tryed to take me again and i left her behind with tail lights and smoke!
She thought she had me tell the boost came on in 3d and then beteeen the pump mods and my GV she got left way be hind and the dodge jokes went back to the ford where that belong
Personally, unless I was towing something heavy and often or racing I wouldn't have the 4.10's in my truck. Poor/limited top end performance and forsaken mpg would be the 2 main reasons I'd be looking for a higher gear ratio in that rearend. Last time I looked you could buy a new ring and pinion set in either 3.54 or 3.73 ratios for our trucks for about $300. Of course installation will cost more. But running either of these ratios would imho make it a more road friendly rig not to mention the improved mpg aspect. Those low 4.10 gears have their place....it's just not in the "normally used" truck most of us here are familair with. Chuck
So in answer to Smokey's original questions: 1) Not necessarily, just depends on if you view limited top speed and lower mpg as "problems." And 2) Why bother, it won't buy you much more than extra shifter rowing.
gears
why not gear ones truck so it will tow the max load u are going to pull out of OD? less monkey motion it the trans. therefore less heat build up. then OD can be used for fuel mileage when empty. i dont tow a lot but this is what i have done for years.
I think that the MPG is more speed dependent than RPM dependent on these trucks, considering how much air we're moving at 80 MPH. I don't think that going 2400 RPM in 3rd gear, for instance, would use any more fuel than the same speed at the corresponding RPM in 4th gear. My sense being that, since the engine only injects the fuel it needs, there's a lot higher of a load on every stroke in 4th gear than in 3rd gear, and so it all comes out even. Right?
This is an interesting conversation.
I have 1 first gen with 4.10s. stock it would run about 78 wide open with the getrag. After a governor spring and pump mods it will run 97 MPH. Im talking at 4700 Elevation in Colorado. I run it all day at 80 MPH plus. Did I mention the service bed and weighing 10,500 LBs.
I put an NV5600 6 speed in my 2WD truck about 3 years ago. I love it.
I installed an NV4500 in my 4WD truck last year, I thought with the extra power I would be OK with the 5 speed. I was dissapointed. If you dont haul much weight than 5 speed is OK but if you are pulling 10,000 Plus all the time than go with the 6 speed.
Unfortunately New Venture (NV) I heard closed there doors and they will be getting hard to find.
The 2WD truck with the 6 speed, I took out the 3.54 gears (when I blew them to pieces ) and installed 3.73 gears. I like the combo.
Did I mention I went from western Colorado to northern Idaho last year and back. I ran 75 MPH at 14,000 LBs and pushing a huge cabover camper. No hill could keep me under 75MPH and got 11 MPGs. That may not impress you but I was pleased.
What a great engine.
Wrong. Higher RPM means more internal friction and pumping losses.
I think that friction is less of a problem then wasting all of the energy it takes to move the 400 pounds of reciprocating mass inside of the engine faster, however.
I'm considering switching to 3.73 or 4.11 gears because i run 33x12.50 tires and live in Washington state with lots of big hills. I'm holding off though to see how the truck pulls a load after I'm done adding perfomance mods (I relaize that I'll never be really done ) becuase even with 3.54s, it does pretty good going up passes pulling a boat with a cabover camper...
