View Poll Results: What color combo should I paint my truck
Black and Gold
44
52.38%
Blue on Blue
9.52%
The original Blue and Silver
32
38.10%
Voters: 84. You may not vote on this poll
3rd gen wheels and, Help me Pick a color
Got the new wheels on yesterday and really like em. Now I just gotta pick a color combo out of the 3 on my truck
Black and Gold
Blue on Blue
Blue on Silver
Black and Gold
Blue on Blue
Blue on Silver
either black and gold or go blue/silver but reverse it to how it is on the cab and fenders. Have the stripe of sliver with the blue top/bottom. Would that be silver on blue?
I think the 3rd gen rims look sharp too.
When I first put the wheels on I just slapped em on and tried drivin around the block but soon realized that that wasn't gonnja work as the was a clearance issue with the tie rod ends. So I just stuck some 1/8 thick washers on the studs between the hub and the wheel and gained just enough clearance for them to clear. I'm still gonna get some spacers to get the right look, the fronts are still tucked just a little to much for my taste also I am gonna upgrade to 9/16 Chevy studs on the front an the use 2nd gen nuts so I can utilize the center caps. The wheels sit right where I want them on the rear though because of the extra width of the D80
I'm not sure how they would fit a 2wd
Ever since I stuck that bed on there I've kinda been leaning towards the Black and Gold but.........
Here's my 3rd gen wheels with hub caps. I used 1.5" spacers to make em fit, and they fit just so that the lockout sticks through the holes i cut in the caps.
Here they are with 315/70R17 Yohohamas.
I personally like blue, but I do like that black and gold because there aren't many like it. I wonder what that blue would look like in place of the black next to the gold? I think i would try that.
Thanks for the pics schamran I was just about to send you a PM to see if you had any close up pics of the front cap
Do you have any down the side shots or under the center cap shots?
How did you machine your caps?
I am running 4" Rancho gasser leaves up front and a custom built by me leaf pack in the rear and I hate to say the stock block stack on a 4" block, but not for to long(I just scored some factory 6 inchers) so total lift in rear is around 7" it was saggin real bad when I got it. From the ground to center of wheel arch is 40" front and 42" in the rear and I'm runnin 315-70-17 BFG AT KO's
BTW sweet ride ya got
How would this interior work with B&G
