3200 spring install??
I looking to install a 3200 spring and am wondering if i need to change any of the o-rings? Have anybody had problems with leaks after? I looked at the thread in the sticky and it looks pretty straight forward. Is there anything else I'll need to know?
Thanks
Thanks
It is a good idea to change the throttle shaft oring and the top cover oring while you are in there. The first one I did I did not change the throttle shaft oring and it did leak when I put it back together so now I make it a point to change those two orings.
Do you have any part #'s?
Maybe change the smaller fuel pin o-ring. I have a whole economy pack of them. You must buy the Bosch rebuild kit to get it. I ordered a pack of 100 count through an industrial supply. If anyone needs one or some........let me know.
For the most part.........the 3200 gsk is straight forward. Just be cautious on not getting dirt or dust into the pump while the top is off.
hounddogks76
08-31-2012 09:22 AM
92smokin blacky
10-03-2010 07:21 AM
