3200 spring
3200 spring
well I'm picking mine up tomrow at a local bosch dealer, how hard is the instal, should i grind the lever after i get gauges?, is that to much power for an auto? thanks
The install is time consuming and a little nerve wracking, but it shouldn't take more than 3 or 4 hours. You will want some help when it comes time to remove and install the spring itself unless you have three hands.
If you aren't towing heavy, the automatic will handle a ground lever and stock injectors.
Fair warning, both my first gens have the fuel cranked up on the pump. The fuel shutoff solenoids can not take the fuel pressure. The rubber tip on the solenoid will get a chunk blown off of it and engine wont shut off any more. If you crank up the VE pumps too far it will happen. There is a shutoff lever on the side of the pump that you can hook up a shutoff cable or modify a second gen solenoid to that lever.
Piers makes a shutoff solenoid that they claim will take the extra pressure Mine lasted 2 days and it was history. Not trying to scare you just letting you know, be prepared. It may happen to you
My modified shutoff solenoid is still working after more than a week. I sanded the end flat and stretched the spring a little to compensate. I will let everybody know when (or if) it fails. Oh, and I haven't been sparing the horses for the last week.
hounddogks76
08-31-2012 09:22 AM
92smokin blacky
10-03-2010 07:21 AM
