3200 spring
Originally Posted by ihpower
he dosnt like what i do to my truck
Things are gonna get really toasty and smoky if you grind the AFC lever. Does Ohio have a diesel emissions test? If so you will not be able to pass with a ground AFC lever. You can drive the truck pretty clean if you want, but if you lay into it before the turbo is spooled you will smoke out the road.
Your mileage is still dictated by your right foot, even after the AFC grind...now being able to control your right foot is an entirely different matter, hehe. I've gotten as good as 21 mpg on a tank with the afc grind...about the same as before the grind. POD injectors are the one mod I can think of that will hurt fuel economy due to their, ahem, less than civilized nature.
g
g
What he said. If you can control yourself mileage will not change. Thing is, you have to do the job the AFC used to do - restrict the fuel at low boost. If you don't do that, you'll send gallons of diesel right out the pipe.
Originally Posted by csramsey640
nope no probs. When you goto a 4k spring, then youll need some additional heavier valve springs, but 3200k is fine.
4k bomber
Anyone out there have a 4k spring on a first gen?
I know engine stress and wear increase exponentially with RPM increase, but does 4k hurt our CTD's?
I'm pretty sure that one full throttle, speed shifting pass in my truck with a 4k spring would chernobyl the drive line! I'd be driving over pieces.
hounddogks76
08-31-2012 09:22 AM
92smokin blacky
10-03-2010 07:21 AM
