3 speed auto to overdrive conversion
Old 05-05-2006 | 08:38 AM
efbeason's Avatar
Originally Posted by PapeCAT
another option is to utilize your 3.07s with a MANUAL TRANSMISSION w/od for best economy and best highway gearing. I put a getrag in place of my 727 for lessthan half of what it would cost to put a GV in... the only real mod you need in addition to all the parts (I bought used resurfaced flywheel, and brand new sachs stock clutch, with used getrag rebuilt by myself) is to shorten the front driveshaft 2.5 inches.
How much extra parts did you have to use. I like the sound of putting a five speed in my truck. I just thought that putting another automatic would be easier. But I would love to put a getrag or nv4500 in my truck. Which one is the best the getrag swap or the nv4500 swap? Which one would take less modification?? Thanks for the input!
Old 05-05-2006 | 09:56 AM
flashgordon's Avatar
You can buy a conversion kit for the nv4500,that has every thing you need to replace the getrage(a conversion that i will do if my getrage fails me!)to a nv4500......shouldn't be two much diff for auto conversion.....May have to change drive shaft langth...But if you go my way(Gear Vender) you will have the have a new rear drive shaft built any ways!
Old 05-05-2006 | 11:16 AM
crunchybuttr's Avatar
Pape,
How did you get around the differences in spline #? I like the way your thinking on this one, though. what's your mileage witht the getrag?
Mike
Old 05-05-2006 | 11:50 AM
Originally Posted by crunchybuttr
Pape,
Mike
I think that you were responding to me??
the getrag haves about 24,000 on it the truck has 214,000!
i haven't done any resurch on the auto to nv4500 just getrag to nv4500,just gessing that it would would be simmiler......Problly comes with some kind of adaper..........the output splines are diff between the Getrag and auto?
Flash!
Old 05-05-2006 | 01:04 PM
Tater93's Avatar
Kellypckp how much frame tweaking did it take. And have you driven it since you did the swap. I'd really like to try a tranny with lock-up but I'd like to hear some first hand experiances first. Thanks, Matt
Old 05-05-2006 | 01:43 PM
jughead's Avatar
od swap
i didnt have to modify the frame or crossmember at all on my 90. just drilled the crossmember holes a little farther back. i did make my trans mount though. used the same starter which should work unless one goes to the lockup trans.
olskooldodge
07-15-2009 11:13 AM
haftrek
11-12-2007 09:19 AM
dieselyakker
08-28-2005 08:47 AM
ckennedy
09-27-2004 11:58 AM
taken5875
08-16-2004 12:56 PM
Quick Reply: 3 speed auto to overdrive conversion
