2nd gen piston pump
Ok, so those are all the fittings i will need to go from the LP outlet to the inlet on the fuel filter, then the outlet on the fuel filter to the inlet on the injector pump. Also, i want to add in a regulator for 15 psi. What fittings will i need to do this? Also, will i need any special lines to go from the return line on the pump to the regulator? How are you guys doing the return lines? do they run from the IP all the way back to the tank? is there any way to do this without running the big line all the way back to the tank for the return line.
The regulator can be plumbed i with a couple hose clamps on the fuel line between th filter and IP.
Return line could be either all the way back to the tank or T into the stock return somewhere.
PeytonMaterne
08-11-2008 10:00 AM
