2800 Rpm
Old 05-27-2006 | 03:56 PM
charger 69's Avatar
2800 Rpm
I pulled the GN this week for the first time since I turned up the pump and with the new torque converter was able to hit 2800 RPM at 60 MPH.There is no name on the tach and I don't know if it is accurate.What RPM do these trucks defuel at? As far as I know there is no 3200 govenor spring in it.
Old 05-27-2006 | 04:27 PM
mhuppertz's Avatar
Was it defueling at 2,800, or still pulling hard?
Old 05-27-2006 | 05:01 PM
Yeah, the truck should be able to hit 2800 RPM with the stock governor spring. It won't pull hard to there, though. It will sorta lay down around 24-2500 RPM. The other possibility is that the tach isn't calibrated properly.
Old 05-27-2006 | 09:53 PM
charger 69's Avatar
It was still pulling,it wasn't slowing down and the overdrive was off,the road was level and we were doing 60-65 mph.As wannadiesel said,I wonder if the tach. is reading right.
Old 05-27-2006 | 10:07 PM
bgilbert's Avatar
RPM and speed sound about right since it was in direct. I bet you have a factory tach.
Old 05-28-2006 | 08:01 PM
wheelo90's Avatar
I can mash it to the floor and hold it at a steady 2800 RPM's.
wheelo
pred
01-02-2007 03:31 PM
pet05
09-20-2006 11:31 PM
tboling
12-17-2005 03:57 PM
wyomingsmoke
08-04-2005 12:47 AM
mcevins
01-12-2004 12:06 PM
Quick Reply: 2800 Rpm
