205 4x4 indicator light switch
wondering if anyone came up with alternate way to energize the dash light, quad 4x4 loves the high priced switch sales, the later weatherpack connector switch is good gm#15594176, still not easy to find, im rigging the '74 ramcharger tcase for install and would like to try to do a 4wd light on that, hope for another option?
nothingbutdarts (02-01-2021)
In the past I've spent hours looking at switches from all makes and models that might be made to work for our application, but the biggest issue is with the thread pattern on our old switches. I lucked out and found a relatively cheap NOS one on E-bay years ago for about $75...it's in my stash since my OEM one seems to still be working.
As for an alternative how about a magnetic HAL sensor on the linkage, with a bracket off the TC so when you shift into 4wd it breaks the connection and lights up the bulb?
ive got 3 bad switches with spade connectors, after getting tcase installed yesterday, found out the switch is hitting floor, ill pry clearance that for removal, switch is kind of weird, living over the detent spring, what does the weather pak kit consist of jimbo? just for fun im going to cut one of these open, see what makes it fail.
sooty, they make these in several different configurations to keep mud and water out
