2 5/8 gauge mounting question
so i just received my fuel pressure gauge in the mail but unfortunatly when i bought it off ebayi neglected to see if it was a 2/16 or 2/58 gauge and now am at a block in the road. i thought it was a normal gauge and was going to mount it on the column cover but its a 2 5/8 so that wont work. im trying to decide which would be better to mount it in a cup on top of my dash or underneath. if i do it on top im afraid that i might not be able to see real well with the pillar guages and that on the left side. and before i eve go mounting it anywhere does anyone else have a fuel pressure gauge in the cab???? my dad was telling me to mount it on the cowl but i dont think the prostreet look works on diesels. i dont see the big deal about mounting it in the cab because autometer uses stainless stell braided hose to connect it. anyone have any input?
I plan on putting my trans temp and a fuel pressure guage in the spot where the cargo light button is ( to the right of the column on the bottom ). As far as mounting it in the cab go for it I know JD730 has one in his cab and if I'm not mistaken so does Dave. As long as the connections are tight you won't have anything to worry about.
I have Fuel-pressure and oil-pressure in the cab on many of my trucks with no negative issues in many years.
VERY IMPORTANT :
On any mechanical fluid pressure gauge, install a ball-type shut-off valve on the line UNDER THE HOOD, preferably by first screwing the valve into the source of pressure, then attaching the gauge-line to the valve.
Should anything go wrong in the cab, such as a gauge-line rupture or come apart from the gauge, the flow of fluid can be stopped by simply turning OFF the valve.
I would not want a GASOLINE pressure gauge inside the cab; DIESEL is an entirely different animal and very unlikely to turn the cab into an inferno.
As to gauge placement, I would opt for a self-built panel above the dash, built to accomodate several gauges; unless one is very short, line of sight will not be affected.
VERY IMPORTANT :
mine is a electronic gauge so no worries of diesel getting in the cab for me. Just make sure you put a shut off valve and you will be fine. As far as where to mount it, i once seen someone use electrical tape and attached it steering column. It did not look to bad actually. I have mine mounted to the left of my ash try at about knee height
A needle valve works well for this, as you can use it to modulate the pump pulses by just barely cracking it open:
http://stuff.is-a-geek.net/PhotoAlbu...ics/CTD_42.jpg
I have about a 2' length of rubber hose from the tap off post filter. That, along with the needle valve, gives me a rock-steady mechanical gauge reading.
good idea on the valve. ill have to look into that. what im curious about is, i have the tapped banjo bolt from geno's and it takes a 1/8th inch male NPT fitting, im sure i can find a ball valve with that style thread no problem, but i know that the line im ordering from autometer has -4 an fittings both ends how could i adapt that to the ball valve??
By ordering a couple of these JIC/NPT adapters :
http://www.discounthydraulichose.com/product_p/2404.htm
Best I can tell, the ones you need are third row down, part number 2404-04-02.
For our purposes, JIC and AN are one and the same, with JIC being usually a BUNCH less expensive.
JIC = Joint International Conference
AN = Army/Navy
Both are 37* Flare fittings; AN is specified/certified for aircraft use; other than that, AN is no different from JIC.
fade94
11-08-2007 10:50 AM
