1st gen a-pillar mounts
Old 04-02-2006, 03:41 PM
triton0708's Avatar
Quick and easy question. Does a single or dual A-pillar guage mount obstruct the vies very much on a 1st gen.? Geno's has these for pretty cheap and they appear to look good. Also, andone have any pics of Apillar mounts on a 1st gen? Thanks in advance.
Old 04-02-2006, 04:38 PM
edwinsmith's Avatar
Received 1,048 Likes on 770 Posts
I don't know about that but I mounted my tach and gauges on the dashtop just to the right of center and angled them towards my face. The mounting cups for Autometer 2-1/16 gauges are available at Summit Racing. They look good there. I'm not crazy about the A-pillar mounts.
Edwin
Old 04-02-2006, 06:22 PM
I have a dual pillar mount and I don't feel that the view is obstructed much. It's definitely less obstructed than a 3rd gen without a pillar pod.
Old 04-02-2006, 07:24 PM
charger 69's Avatar
I've got a dual mount on mine with the boost and pyro in it and don't have any complaints and I've got a factory tach. on the left side of the dash also.
Old 04-02-2006, 08:36 PM
gman07's Avatar
I also have a pyro/boost combination on the pillar. It blocks view a little, but its not bad, and it's easy to get used to. Here's a picture:
Old 04-02-2006, 11:41 PM
AlK
AlK's Avatar
I have boost and pyro in the pillar and the tach on dash and I don't find that they impede my vision too much.
Old 04-03-2006, 06:47 AM
KartRacer's Avatar
AIK, where did you get the red dash paint? That appears to match pretty good. Do you have a color code or part #? Thanks.
-Steve
Old 04-03-2006, 07:14 AM
fishin fever's Avatar
hiding wires
Hi guys side bar to main topic have people run there main wires and boost hose under the factory pillar trim to hide ,with a hole allowing access to gauges of new pod?
Old 04-03-2006, 07:22 AM
gman07's Avatar
Yep, thats how I did it.
Old 04-03-2006, 09:06 AM
nailhead's Avatar
Gman, where'd you get that mount? A dash mount won't work for me.
- Chris
Old 04-03-2006, 12:49 PM
triton0708's Avatar
Thanks a ton for the replies and pics, just what I needed to see.
Old 04-03-2006, 02:58 PM
bigragu's Avatar
A-pillar mounts
Combine Geno's dual and single a-pillar mounts and you can have three. Place/mount the single pod towards the bottom, about 3/8" from the top of your dash. Trim about a 1/4" or so from the bottom of the dual pod and all will work and look like a solid 3 pod if you pre-paint the pods to match your interior trim. If you can swing the funds for extra guages, buy another dual pod like the one for the a-pillar and the steering wheel pod for the '94-'98. This steering pod will wiork on ours and is a great spot for an Isspro tach. The other dual pod will affix on the trim right above your driver side window, which can be used for fuel and oil pressure guages. I have full view of a total of 6 guages, non of which are in my line of sight to the road. Remember, though, to make it look trick, you gotta paint the pods to match the trim! Carmyne.
PS- I have this set up. Looks cool. Sorry, no pics from me.
Old 04-03-2006, 05:58 PM
charger 69's Avatar
Make sure you don't pinch the boost line like I did the first time when I screwed it back in place.
Old 04-04-2006, 01:10 AM
AlK
AlK's Avatar
KartRacer,
I bought it at Canadian Tire a few years ago. The colour is called medium red and the part # is 47-8062-4.
Al
Old 04-05-2006, 02:28 PM
triton0708's Avatar
AIK, that is the red int. paint that I need also. any place we can pick it up in the U.S.?? Keep 'em coming ya'll. and thanks...
Quick Reply: 1st gen a-pillar mounts
