1st Gen NV4500: Will 727 X member work w/ mods?
Old 10-30-2014 | 10:49 AM
acbarnfinds's Avatar
Just getting ready to start my D250 Cummins 727 to NV4500 swap. Last thing I need know is if the 727 cross will work with mods? And does anyone know how much shorter the drive line will need to be? I've read several threads on having to spread the frame (4x4) to get cross back in. Is this the same on 2wd?
Thanks guys,
AC
Old 10-30-2014 | 11:29 AM
You would have to heavily modify a 2wd cross member to get it to work with the 4wd system. Your better off, in my opinion, to get a 4wd cross member. You can get from a manual, or auto truck...they are the same unit, other then the adapter to the actual transmission.
You might have to drill some new holes in the frame for the 4wd cross member, but other then that it's a direct swap, with no frame spreading needed.
Old 10-31-2014 | 10:26 AM
Like Trashing said, get a 4x4 crossmember and put it in.
You should space it back one hole in the frame and drill one new hole in the frame, further back for the crossmember.
Old 11-09-2014 | 11:50 PM
Appreciate the help guys. I heavily modified the 2wd x member.
Old 11-10-2014 | 10:02 PM
Can you toss up a pic or two for future searches and reference.
Old 11-11-2014 | 10:33 AM
You bet. As soon as I get back from this business trip.
acbarnfinds
11-09-2014 08:11 PM
12valvin
07-24-2009 12:07 PM
freds89
05-25-2009 02:52 AM
Big Joe
07-01-2005 05:34 PM
zookeeper
03-17-2005 06:27 PM
