1993 tranny noise
1993 tranny noise
I have a 1993 dodge w250, with what I assume is the a518 with the lockup wired to a toggle switch. It seems fine in all gears except overdrive, as soon as I flick the switch for overdrive it starts shuttering, and gets worse as I pick up speed, anyone have any ideas? It sounds like a bad bearing but only happens in o/d
The whole time it's in overdrive it shudders, I can feel it shift but nothing unusual, it starts as soon as it shifts into od and gets worse as I pick up speed.
There is a bearing in there that could be bad. Also maybe it is not fully engaging and the shudder you feel is the slippage. I am not sure someone will chime in that knows more than me.
Yep, I did mean overdrive, it only happens in overdrive, no other gear, it makes a vibration as well as a shuttering that gets worse with more rpm/speed,feels like it's slipping but only in overdrive, any help is appreciated!
Black Dog
12-03-2009 08:18 PM
