1993 350 cummins ext cab single rear wheel??
did they make a 1993 350 cummins ext cab with the single wheel rear tire?
ive seen the dually 350 ext cab but not the 350 single wheel ext cabs
Thanks
ive tried goggling it and i cant find anything
could it have been a special order?
The reason i ask is because this is how my truck is. I try decoding the vin and it said 350 cummins less dual rear wheels? Any help would be much appreciated.
Thanks
Apparently they did. There is 1 for sale locally I'm interested in.
I have owned a few 1st gen W-350 SRW Cummins 12Vs.
I bet it is stock, or someone could have added the emblems over the years.
Checking the GVWR might give you some clues.
8510# is the GVWR on a '92 12V auto W-250 ex cab I just checked for you.
http://www.decodethis.com/ try this decoder
here is my vin- 3B7MM33C0PM161162
still cant tell if its a stock single wheel rear tire
it says it is a 350 model
it's a DRW didn't srw have 235's 16's
1993 Dodge Ram 350 Club Cab 8-ft. Bed 4WD
General
Equipment
Colors
Recalls
VIN 3B7MM33C0PM161162
Vehicle Accidents/Service Get Vehicle History Report NOW
Year 1993 Engine Type 5.9L L6 TURBO DIESEL
Make Dodge Driveline 4WD
Model Ram 350 Ground Clearance No data in.
Trim Level Club Cab 8-ft. Bed 4WD Front Brake Type Disc
Manufactured In MEXICO Rear Brake Type Drum
Body Style EXTENDED CAB PICKUP 2-DR Anti-Brake System Non-ABS
Transmission 5-Speed Manual Overdrive
4-Speed Automatic Overdrive
Standard Seating 5
MPG Hwy No data miles/gallon Optional Seating 4
MPG City No data miles/gallon Tires 215/85R16
Dealer Invoice No data USD Wheelbase 149.00 in.
MSRP $24,657 USD Curb Weight 5981 lbs
General
Equipment
Colors
Recalls
Standard Seating 5
I believe the 235/85R16 tire is the factory size for the SRW Cummins trucks.
Ya that's a DRW vin although they did make SRW 350's in 1993, that truck left the factory as a dually
POSITION INTERPRETATION CODE = DESCRIPTION
1 Country of Origin 1 = Manufactured By DaimlerChrysler Corporation
..........................3 = Manufactured By DaimlerChrysler De Mexico
2 Make D or B = Dodge
3 Vehicle Type 2 = Incomplete with Side Airbag
.....................3 = Truck with Side Airbag
.....................6 = Incomplete Less Side Airbag
.....................7 = Truck Less Side Airbag
4 Gross Vehicle Weight Rating G = 5,001-6000 lbs.
........................................H = 6,001-7,000 lbs.
........................................J = 7,001-8,000 lbs.
........................................K = 8,001-9,000 lbs.
........................................L = 9,001-10,000 lbs.
........................................M = 10,001-14,000 lbs.
........................................W = Buses/Incomplete Vehicles with Hydraulic Brakes
5 Vehicle Line A = Ram Pickup 4X2
...................U = Ram Pickup 4X4
...................N = Ram Pickup 4X2 DX Family
6 Series 1 = 1500
............2 = 2500
............3 = 3500 Less Dual Rear Wheels <--------- my 6th letter is a 3
............4 = 3500 With Dual Rear Wheels
............5 = 4000 DX Family
7 Body Style 6 = Conventional Cab/Cab Chassis
..................8 = Quad Cab Full Rear Doors[/COLOR]
8 Engine K = 3.7L 6 cyl. MPI Gasoline
............N = 4.7L 8 cyl. MPI Gasoline
............D = 5.7L 8 cyl. SMPI Gasoline
............6 = 5.9L 6 cyl. Turbo Diesel 24v
............C = 5.9L 6 cyl. Turbo Diesel High Output
9 Check Digit 0 through 9 or X
10 Model Year 4 = 2004
11 Plant Location S = Dodge City
........................G = Saltillo
........................J = St. Louis (North)
12 thru 17 Vehicle Build Sequence
6 Series 1 = 1500
Well yea they did make 350 SRW trucks, 1 more leaf in the rear pack, bigger rear brakes (1/2" wider) and a higher GVW. Compared to a 250, barely any difference. got you a bigger frame on the 89-91.5 trucks if it's a 350 even if its SRW.
Duallies on the other hand have a bigger D70HD rear verses the D70U rear the SRW trucks have.
Not sure if that decoder is right for an older truck like yours. I'm pretty sure that on the older trucks, the 6th digit was a 3 regardless of whether it was a DRW or SRW type 350.
Also, note the 4th digit indicates a GVWR over 10,000 lbs, if that decoder is to be believed. A SRW 350 would have a GVWR of 8800 lbs, and therefore should be a "K", not an "M".
well heck... the title does show one ton. And it is a 1993.
Also it has the regular bed with one tire in the back. not duals
So was it a SRW from the factory? How can i for sure find this answer out?
It doesn't just have the 350 badges on it . Like i said the title shows 1 ton
found this decoder
Result of VIN decoding process (No guarantee)
VIN: 3B7MM33C0PM161162
WMI / VDS / VIS: 3B7 / MM33C0 / PM161162
Model: W350 Pickup
Make: Dodge
Manufacturer: Chrysler de Mexico
Model year: 1993
Country (Region): Mexico (North America)
Sequential number: 161162
Fewer than 500 per year: NO
More information: Get Certified Vehicle History Report AND Get Complete VIN Audit
Anti-brake system: Non-ABS
Body style: EXTENDED CAB PICKUP 2-DR
Brake - front: Disc
Brake - rear: Drum
Cargo volume: —
Consumption in the city: —
Consumption on the highway: —
Curb weight: 6025 lbs / 2738.6 kg
Driveline: 4WD
Engine capacity: 6 Cylinder, 5.9 L, Turbo
Engine series: 6-Cyl. 5.9L
Engine type: 5.9L L6 TURBO DIESEL
Fuel tank: 30.00 gallon / 113.6 liter
Fuel type: Diesel
Ground clearance: —
Optional seating: 4
Overall height: 74.20 in / 188.5 cm
Overall length: 231.80 in / 588.8 cm
Overall width: 94.20 in / 239.3 cm
Standard seating: 5
Steering Type: Recirc
Tires: 215/85R16
Trim level: Club Cab 8-ft. Bed 4WD
Turning Diameter: 46.80 in / 118.9 cm
Vehicle type: Pickup Truck
Warranty distance: —
Warranty duration: —
Wheelbase: 149.00 in / 378.5 cm
Model: W350 Pickup
Make: Dodge
Model year: 1993
Brake - front: Disc
Brake - rear: Drum
Cargo volume: —
Driveline: 4WD
Fuel type: Diesel
Ground clearance: —
Optional seating: 4
Standard seating: 5
Tires: 215/85R16
