1992 W350 4x4 clubcab lift ?
Just picked it up this weekend and wanted to know if a 4 or 6" lift is poss. without driveshaft issues and does anyone have pics of lifted 1st gen duallies , Thanks
its not a clubcab mine was a crewcab but if you look in ad section under sold you will see some pictures of my truck I just sold it had 8 in front springs with 3 in body lift but was also running 39ish tall tires
you can run the skyjacker setup or have custom springs made.the skyjacker 4 inch kit requires no driveshaft modifications but the 6 inch requires a front lenghtening.its a good idea tho however, to have your front lengthened on either of the kits. skyjacker.com will show you.they are the only ones i am aware of that have made a kit for our trucks.
Muted User
superlift makes a lift for the W250 truck, pretty much the same truck, http://www.superlift.com/Catalog.asp?P=K473 superlift kits are good quality.
actually that looks to be a kit for the gas model trucks.it will say in bold letters for diesel application if it is for a diesel.to my knowledge superlift doesnt have any first gen stuff.you also want the correct spring selection in your truck as the diesel spring pack will be heavier than the gasoline motor config.
Thanks so far guys , I found a lift through skyjacker and did not want to buy the first thing I found , Just wondering if there are any other options , This is my first leaf sprung 4x4 and my first 1st gen so I am totally lost on all aspects like susp. , and perf. upgrades , the truck is bone stock and in need of MODS !!! , More so I am needing the mods , you all know what I mean.anybody know of diesel performance shops in N. Ga. or near Chattanooga , Tn. Unfortunatly I had to get rid of the 06' 3500 due to finances and am starting from scratch but still had to have a diesel Dodge . Is there any other choice....
sandpuller2004
11-09-2004 03:27 AM
