1992 D250 Fan Replacement
Wow, nobody wants to answer this? You need a 1 1/2'' wrench, and some of those big honkin' channelock waterpump pliers. The clutch is held on with left hand threads. I use a thick rag wrapped around the pulley and held with the pliers. With any luck you can break it loose (clockwise). They can be a real pain sometimes. I've also used a makeshift holder from a section of an old serpentine belt and some vice grips. I'm sure there are better ways, it's just worked for me. Good luck, it WILL come off !! Jim
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
I always try hitting the wrench with a hammer a few times with the belt on and some times it will loosen up. once it breaks loose it should turn easy by hand.
again it is left handed threads.
I cheat though. an air hammer will break it loose in seconds but not everyone has an air compressor and air hammer
Good luck
![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
Good luck
If you want to use the correct tools for the job and don't need them today, email Harold Bowers - rvhvnfun@juno.com - about his wrenches. One slips over the ring of bolts on the fan hub to hold the dang thing still, the other fits the fan. Last I knew he wanted $20 for the set.
jcb
11-27-2005 05:45 PM
