1990 dodge w250 injection pump leak
Difficulty depends on your mechanical aptitude. I re-sealed mine....messed it up the first time which required another pump, then got it perfect the second time. Hard..not really, intimidating...you bet!!
Can you tell exactly where it is leaking from? If it is on the backside, near the block, you will have to remove the pump to get access to it. Some leaks can be fixed without pump removal. Like said above, check the sticky. I used some pages I printed out to re do mine a couple of years ago. It wasn't too bad.
