1990 D250 to W250
#1201
Very nicely done there Mark!
mknittle (04-21-2017)
#1203
Received 1,647 Likes
That's wicked cool, Mark....
The only one in existence, I gather...
#1205
#1206
#1208
thrashingcows (04-22-2017)
#1210
How goes the parts install? Still piling up from UPS, FedX, and USPS?
#1211
there are a couple little things to get but the parts spree is pretty much over I assembled the turbo aside from the turbine housing because I have to do some work on the down pipe to make it fit right. And every time i make a trial fit the I can just mount the housing instead of wrestling the whole turbo.
But I haven't got there yet.
today I adjusted the valves and got the top off the injection pump to install the 366 spring and the top hat spring flew away. At least i found the other two parts. Oh well. tomorrow is another day.
I also ordered the spring for my lift pump from Fastenel. It should be here Monday.
I ended up painting the valve covers I was going to polish because the ones on the truck were way better so those will get polished. I don't even know why I am doing that
While I have the plate that the throttle cable mounts to off I will replace the fuel heater O-ring.
#1212
366 governor spring installed and O-ring on fuel heater replaced. next on the list is the piston lift pump. the lower pressure regulator spring is supposed to be in today. The left hand thread Hiem joint for the throttle link is supposed to be here Thursday.
mknittle (04-24-2017)
#1214
