1990 D250 to W250
Old 04-18-2016, 08:04 AM
  #961
mknittle's Avatar
And as Homer Simpson is fond of saying..."Trying is the first step to failure!"
Glad you didn't fail on this one though.
I remembered reading A thread here someplace that several guys said their brake adjusters didn't work. I figured I better check them.
Once I figured out why they didn't work. Moving the hole seemed like the easiest solution.
Old 04-18-2016, 06:00 PM
  #962
j_martin's Avatar
Typical Homerism butchering of a good addage.
To try risks failure.
Not to try guarantees failure.
Old 04-18-2016, 08:53 PM
  #963
Received 1,647 Likes on 1,120 Posts
My wife is a propnent of this, except she mostly succeeds at failure, by not trying at all because of fear of failure, vs trying and failing. Very successful at failing, either way..
Old 04-19-2016, 08:02 AM
  #964
mknittle's Avatar
My wife accuses me of that. but sometimes I can see failure coming and the only way to avoid it is to avoid the the whole situation in the first place.
Old 04-19-2016, 08:03 AM
  #965
mknittle's Avatar
My wife accuses me of that, but sometimes I can see failure coming and the only way to avoid it is to avoid the the whole situation in the first place.
Old 04-19-2016, 08:23 PM
  #966
mknittle's Avatar
Today I got the new rear wheel bearings, seals, drums and axles in.now to turn it around and start on the front.
Old 04-20-2016, 07:33 AM
  #967
mknittle's Avatar
Not truck related but this morning when I went out to check on a couple rat traps. I got two rats in one trap.
Old 04-20-2016, 08:40 AM
  #968
What did you win ?
Old 04-20-2016, 09:33 AM
  #969
mknittle's Avatar
What did you win ?
Two for the price of one. Half the peanut butter twice the prize.
Old 04-21-2016, 03:03 PM
  #970
mknittle's Avatar
This morning I stripped the outer parts off my front axle to do the king pins. One cone was a real PITA. I ended up heating the knuckle up pretty hot before it popped loose.
now to go take out the lower bearings
Old 04-21-2016, 03:13 PM
  #971
Diesel_Dawg's Avatar
Mark - This has been an informative thread for me and I have enjoyed following your progress. Keep on truckin!
Old 04-21-2016, 04:26 PM
  #972
mknittle's Avatar
Thank you much. I try to help wherever I can.
Old 04-21-2016, 08:05 PM
  #973
mknittle's Avatar
while dissembling this mess I noticed the drivers side bushing was missing the retainer that goes between the spring and the bushing was split and deformed. good thing I am one of those "while I am in there" guysI started to replace a stub axle and bearing.
The king pin kit I ordered didn't have the retainers either. But I need to order a slinger for the stub axle anyway.
Old 04-26-2016, 07:37 PM
  #974
mknittle's Avatar
This morning I found that the axle seals are leaking So the carrier comes out. always something
NJTman (04-26-2016)
Old 04-26-2016, 10:00 PM
  #975
MrFusion's Avatar
Man, you're gonna have a new truck by the time your done!
Quick Reply: 1990 D250 to W250
