1990 D250 to W250
Old 05-23-2015, 02:42 PM
  #781
mknittle's Avatar
This morning I did some bending on a piece of 3/8" tubing. First off I had to do a quick fix on the tube bender.
I retrieved a 11/16-18 flare nut for 3/8" tube from an old Chevy power steering hose.
On the first try the radius looked good but there was a straight section just after the nut that was about a 1/2" too long. This caused the outside of the radius to interfere with the frame.
It took me a little while to come up with plan B. So I cut the end off to retrieve my precious nut
This time I started with a straight piece of tubing with no nut or flare. I put it in the bender as far as i could get to the end and bent a 90*. Now I put the nut on and double flared the tube. Right off it looked better.
So I tried it. BINGO it cleared the frame
Now that I know how to do it I can start with a longer tube and Braze one of these on the end.http://www.summitracing.com/parts/aer-fbm2872
I can also make a brace to the hole in the frame in picture 4 .
Attached Thumbnails 1990 D250 to W250-100_5593.jpg   1990 D250 to W250-100_5591.jpg   1990 D250 to W250-100_5595.jpg   1990 D250 to W250-100_5597.jpg   1990 D250 to W250-100_5598.jpg
Old 05-24-2015, 11:18 AM
  #782
mknittle's Avatar
Here is my parts list for the hoses.
Hose
http://www.summitracing.com/parts/aer-fcg0606
2, 90* ends for the booster ends.
http://www.summitracing.com/parts/aer-fbm1389
1, 45* for the steering gear end.
http://www.summitracing.com/parts/aer-fbm1386
1, 5/8-18 45* for the pump end
http://www.summitracing.com/parts/aer-fbm1382
Note the flow valve has to be changed to the old style with a inverted flare.
Old 05-24-2015, 11:33 AM
  #783
mknittle's Avatar
And the adapters.
One each of these on the booster.
http://www.summitracing.com/parts/ear-961956erl
http://www.summitracing.com/parts/ear-961955erl
This for the steering gear end
And I have the early style GM flow valve.
Here is an alternative for the pump end.
http://www.summitracing.com/parts/afc-37130
Old 05-24-2015, 04:06 PM
  #784
mknittle's Avatar
This shows how simple the hoses are to make. I don't care for his method of cutting the hose but you get the idea.
Old 05-25-2015, 06:51 AM
  #785
Received 2,536 Likes on 1,677 Posts
Any old excuse to use your chisel while working on your truck.
Old 05-25-2015, 08:52 AM
  #786
mknittle's Avatar
I was surprised at that.
Old 05-30-2015, 03:54 PM
  #787
mknittle's Avatar
I ordered a hydroboost rebuild kit today. Other than that I dug 300 feet of trench through some pretty hard shale.
Old 05-30-2015, 06:42 PM
  #788
Received 1,334 Likes on 864 Posts
What one did you go with? Complete kit with all the small parts, or just the seals?
Old 05-30-2015, 07:27 PM
  #789
mknittle's Avatar
I went with the complete kit. The price difference isn't that much and you know how it goes. Sure enough if I bought just the seal kit something would need replacing that I didn't have.
Old 05-30-2015, 09:23 PM
  #790
Well thanks for that...I only went with the seal kit....Doooh!
Old 05-31-2015, 08:09 AM
  #791
mknittle's Avatar
You probably will be fine with that. Now all we have to do is find the time to tear them apart.
Old 06-17-2015, 09:11 PM
  #792
mknittle's Avatar
Today I finished disassembling and cleaning my hydroboost. I also made a makeshift seal installation tool out of a calking tube spout. I haven't tried it yet but it fits on the input pushrod nice and tight.
This in theory should work better than the packing tape used in this write up{ a little farther than half way down the page}.
Hydroboost reseal tutorial (long)
I will post some pictures tomorrow.
Old 06-18-2015, 01:56 PM
  #793
mknittle's Avatar
not too complicated.
Attached Thumbnails 1990 D250 to W250-100_5606.jpg   1990 D250 to W250-100_5605.jpg
Old 06-18-2015, 11:07 PM
  #794
Like it!
Old 06-19-2015, 09:31 AM
  #795
mknittle's Avatar
Like it!
When I worked for *** & SONS I made a bunch Of seal installation tools and piston seal compressors. We made all our own hydraulic actuators. linear and rotatory. Fun stuff I miss those days
Quick Reply: 1990 D250 to W250
